1 - 20 of 24 Posts
Yeah, and doing all of that work while it's out of the vehicle is so much easier, too. Congrats on getting the new-to-you engine.
Heck the man even has room to work and I see the engine compartment appears to have gotten a proper bath! Hose the old girl down! I'm liking the looks of those shiny new headers. Looking solid for sure.
Im curious, Whats the power output of your new setup? The original motor, does it have a lot of miles or did you just want an upgrade? Keep up the good work, looks like you know what your doing.
Yeah, any chance of some details on the alt/ power steering relocation, such as pictures of said brackets, maybe? Please?
Power steering pump and alternator are switched and looks like the alt is mounted a bit higher.
Discussion Starter · #8 ·
I'll post a couple of pictures, on the jdm engine the alternator, power steering, and The AC compressor are on the opposite sides from the American engines. you can use the same hard where and bracket to swap them to the correct side.
Discussion Starter · #9 ·
77023
This is the mounting bracket that was used for the AC compressor on the JDM engine there are slight differences
77024
This is the only difference i found in the bracket
77025
77026
Discussion Starter · #10 ·
Let me start off by saying by no means am I a mechanic, I can turn a wrench and get my hands dirty but I'm not a mechanic. (I've worked in the construction and trade show fields) I was told by two shops that I had burnt valves and the engine was toast. I lost alot during the pandemic so I didn't have to money to buy another vehicle (used car prices in the Atlanta area are crazy high) so I decided to fix what I already have. I do think I might gain a couple of ponys but nothing ground breaking.
I'm more interested in how the P/S pump is mounted on the JDM, since that would get rid of ALOT of extra/ un needed tubing/hoses/leakpoints.
Reactions: MeToo
Discussion Starter · #12 ·
77029
Hopefully this helps
Thank you. This helps considerably! goes to look in parts mountain for possible pieces...
Sir, if you find a bracket, please share. I recently upgraded from a 2001 to a 2004. Eventually, I will be replacing the PS hoses, so if I can get the pump to the "proper" side, I'd be quite happy to figure out a means of getting fluid to the steering box.
TIA!
I will, of course. My parts mountain has ALL kinds of stuff in it, so, hopefully, I can find a production piece (and remember what it came from) to use.
EDIT- first blush, looks like some P/S bracket pieces from a *eep 4.0 or maybe a Garbage Motors mount are strong players...
Reactions: MeToo
Discussion Starter · #17 ·
77045
I didn't change the oil dip stick because I was afraid of braking it trying to remove it. I paid the price for that while installing the headers after I got the engine in. I had to fight to get the dip stick in between the pipes while getting it twisted in to place.
Looks like you've been busy alright. Keep the good things going there. Hope she fires up all sweet and neat real soon!
03 XE A/T, SC coming soon
I also swapped oil pans and oil filter housings when I did mine. I would strongly recommend installing new spark plugs because the Japan spec uses copper plugs instead of platinums.
Discussion Starter · #20 ·
Tell me more about the differences in the spark plugs I was going to leave them
1 - 20 of 24 Posts
