I have a 2004 2 wheel drive that came with 15" wheels. All the websites that you enter the year, make, model and engine say the vehicle has 16s. Does anyone else have 15s and if so where can I find wheels for it?
Xterras came factory with 16's or 17's, 15's are a common replacement and widely available. Some prefer 15's for wheeling as it gives more tire sidewall and flex at low pressure. Are you after a factory look?
The bolt pattern for first gen Xterras is 6 lug 5.5 inch or 139.7mm, the same as some Toyota and Chevy wheels. I'm guessing you have tires you want to keep but don't like the wheels?
My girl just got a 2002 2wd xterra with 86k on the clock and she wants to have it lifted. Ive been looking into lift kits but im not sure what I think of the options out there. So I got to wondering whether components from a ~2000 frontier front suspension would swap seamlessly to her xterra or...
I am a new member, and new to the Xterra in general. I picked up a used 2009 and I need to replace the rear axle. There are several good use around but I am confused as to the gear ratio. I cannot find a tag on the axle, and the door sticker ends just below the "Trim X "
the Model number is...
Newbie to towing and need some advice. 2001 Xterra. Ownswers manual says it can pull 5000lbs. Looking to buy a camper with dry weight of 3990lbs. Any advice on if I should pull it being that close to the max towing capacity.
Hi guys! I would like to ask a question ? Tomorrow morning my mechanic will install my manual lucking hub on my 2000 Xterra. Unfortunate the kit what I got from Warn industries not included the two snap rings. I would like to know if anybody could tell me what size are this snap rings. Thank you...
Hi I'm looking at buying this xterra and wondering what more experienced owners can recommend. I'm a bit concerned about the CEL and catalytic converter problem. Any input is appreciated! ................
2006 Nissan Xterra Off-road
Open to offers
296,XXX kms
New timing chain, tensioners and...
