Hello all, I puchased an 06 xterra (240k miles) a few days ago. The previous owner stated that the head gasket blew, and that oil and coolant were mixing together in the radiator. I've taken everything apart down to the intake manifold so far. The car still runs, just not great. High rev when started, and car shoots some white smoke out of the back. Previous owner said he drove for a little while, but stopped when he found out what was wrong. Here is what's been found so far:
Any thing wrong with my logic here, or does anyone recognize any of these as being part of something far worse?
Attached are two pictures of the gunk in the radiator.
- Oil is leaking at the corners of both valve covers. Cannot confirm for engine gasket yet.
- Radiator has something weird in it. Coolant yes, but it looks more like congealed fat from cooking - light tan and all.
- The VIAS control solenoid valve has some slight fraying on it, exposing the wire.
- One ignition coil on passenger side bank has the rubber insert on the bottom torn.
- An O2 Sensor right below the steering wheel has oil all over it.
- Small animal nest under intake manifold.
- Codes:
- P0031 - Heater Control Circuit - Low Bank 1 Sensor
- - I'm guessing that oil covered O2 sensor might be dead. Code reader said it had voltage though.
- P0300 - Random/Multiple Cylinder Misfire Detected
- Probably that torn ignition coil.
- P0430 - Catalyst System Efficiency Below Threshold Bank 2
- My guess, has to do with the O2 sensor mentioned earlier.
- P1148 - Closed Loop, Bank 1
- Also an O2 Sensor issue from what I've read.
- Timing chain kit, do everything in there.
- Timing chain gasket kit.
- Gasket kit, this thing is puddling oil.
- Clean out the radiator of that gunk.
