Have to wonder if the thermostat is opening properly. Was that replaced with the radiator? A hot upper hose and cooler bottom hose is normal. A warm upper hose is not normal if the engine is up to temp. More fingers pointing at the thermostat there. Thermostats can be installed upside down if that was done.My 06 Xterra runs hot unless I have my heat on. I had a new radiator put in. When I feel my radiator hoses the top one is warm and the bottom is cold..Any ideas?
Well, if it came in a housing then there is no upside down with those I don't believe. It might still be defective new out of the box.Yes my thermostat was replaced also My thermostat came in a housing and I'm not sure it can be put on upside down but I will most definitely look into it.
I helped a friend with her car after she bought it from some dude who said that he had changed the t-stat.Yes my thermostat was replaced also My thermostat came in a housing and I'm not sure it can be put on upside down but I will most definitely look into it.
After I got it changed and it did exactly what you just explained I did take it off and put in a boiling pot of water but had no idea on what exactly u was looking for. I didn't see anything open or close.I helped a friend with her car after she bought it from some dude who said that he had changed the t-stat.
The idiot put it in backwards and her car overheated less than 5 miles after buying it, and that was after taking it for a spin!
If it is in backwards, it'll act like it has failed and keep the coolant from flowing. I suggest that you remove the t-stat, test it, and replace it if it fails the test.
That would be a for sure sign of a thermostat that has failed to open and cause your engine to overheat. The plunger would normally slide up and open to allow the coolant to flow. It should have opened at about 190 degrees well before the water boiled.After I got it changed and it did exactly what you just explained I did take it off and put in a boiling pot of water but had no idea on what exactly u was looking for. I didn't see anything open or close.
Good news! DIY satisfaction. Get it done right, do it yourself!New thermostat is out in and so far so good, thanks all for the help.
