1 - 6 of 6 Posts
04 xterra with 165000 on it all of a sudden is super hard to start and when it does start up runs super smooth.. if u slowly rev it up u can take it to 45-5k rpm but if u jump on it, dies out. Any thought?
Discussion Starter #2
Also throws no codes and I can put it in gear even run a/c when at idle and is fine until I try to rev it up then it dies.
Discussion Starter #4
It dies and makes it even harder to start back up. Were talking like 30 sec to a min of cranking it over. Once u rev up were it bogs out, even if u let of the pedal it will die not matter what
Sounds like a fuel issue. Maybe a pump getting weak or a clogged filter, either the main fuel filter or the pickup filter on the pump.
Discussion Starter #6
Did more research and my best guess was distributor. I was correct runs like a champ now
1 - 6 of 6 Posts
