1 - 4 of 4 Posts
Hello,
I was at the gas station and when I got in my car to leave the car wouldn't start. It doesn't crank or many any noise. All the lights, alarms, and radio still work though. It was running fine before this. Tried jumping it, replacing the battery in the key fob, and resetting the security anti-theft system. Ended up having the car towed home and I still can't figure out the issue! Battery and starter both look good. I'm completely stuck on trying to figure out why the car won't start. Any tips or advice would be appreciated!
Check all your fuses, and the connections at the positive terminal. Nissan are known for their positive terminal not connecting properly, also, run a hot wire from your battery to your starter/use a clamp on remote starting tool and test the starter, if that is good, it is somewhere between the battery or starter, or key and starter
Sent from my SM-N920V using Tapatalk
1 - 4 of 4 Posts
