Lo All,
I'm trying to track down some information for my brother real quick. He's in the armed services and tends to be too busy to bother with the internet. My question is if there is a write up on how to do a Auto - Manual conversion on a '02 Xterra and what parts would be needed for the conversion?
So far I think he needs:
Transmission
throw-out bearing
clutch
pressure plate
flywheel
clutch master / slave cylinders
clutch pedal
manual shifter
manual shift cables
Will he also need:
ECU
driveshaft
hubs/knuckles
engine mounts
wiring harnesses
or anything else?
Neither of us have done a swap like this before so we're just trying to get all the necessary information first.
Thanks
Transmission
throw-out bearing
clutch
pressure plate
flywheel
clutch pedal
manual shifter
manual shift cables
Will he also need:
ECU
driveshaft
hubs/knuckles
engine mounts
wiring harnesses
or anything else?
Thanks
