I found a broken ground strap on driver side in the engine bay, toward the front. Does anyone know where it is supposed to ground to? There is a connect on the non broken side.
Did you ever reconnect? Still haven't on mine but it's on the list.I had a similar question some time back and I remember people saying it goes to the catalytic converter heat shield somewhere.
I never reconnected mine though because it has worked fine for years without it...but I suspect it may be the same.
