I have a voltmeter on my X, over the past few days the voltmeter would read low (10-11v) when I was at an idle but would go to the normal range (13-14v) when cruising. I was idling in a parking lot for like 2 minutes when it just died. It cranks, but won't start back up.
Within the past 10k miles I've replaced:
-timing belt/pump/t-stat
-battery
-plugs/wires
-distributor cap
my money is on the distributor rotor. fuel filter was replaced like 7 years ago. it's still on the on the original fuel pump i think. i should also note that it's throwing a bad cat code.
-battery
-plugs/wires
-distributor cap
