Has anyone ever taken one out? I have an idea for a replacement/modification that I would like to look into. I want to remove the original and replace it with a home fabricated Aluminum "box" if you will. I'm imagining a box a bit shorter in height than the original but extending into the back floor board a little bit. I figure Ill line it up so that it is about 1/8" behind the shifter while it is in 4th gear, as that should be the furthest back that the shifter will ever be. I don't generally have adults in my back seat, so leg room isn't too much of an issue. I have even considered taking the box all the way back to the back seat. I'm thinking of a box large enough to conceal my M4 while still having access when needed, yet "out of sight, out of mind".
Thanks
Thanks
