1 - 4 of 4 Posts
Has anyone ever taken one out? I have an idea for a replacement/modification that I would like to look into. I want to remove the original and replace it with a home fabricated Aluminum "box" if you will. I'm imagining a box a bit shorter in height than the original but extending into the back floor board a little bit. I figure Ill line it up so that it is about 1/8" behind the shifter while it is in 4th gear, as that should be the furthest back that the shifter will ever be. I don't generally have adults in my back seat, so leg room isn't too much of an issue. I have even considered taking the box all the way back to the back seat. I'm thinking of a box large enough to conceal my M4 while still having access when needed, yet "out of sight, out of mind".
Thanks
Love the idea...I would like to put a safe in mine so I can carry my ruger on road trips...xuriois to see what you come up with...I cannot lose the cup holders front or rear though...so it would be interesting for me to design one also...I so need to start learning some kind of CAD skills
Darin
01 Xterra SE 4x4
COMING SOON:
Wish list:
1 - 4 of 4 Posts
