The original leaf springs on my 2000 Xterra XE both cracked the other day. I ordered from new Husky leaf springs (69-257) from Rock Auto as well as new u-bolts.
When attempting to install the new leaf springs, the centre bolt on the Husky leaf springs is too long for the alignment hole under the axle. I noticed that on the original leaf springs the centre bolt does not stick out above the nut, but on the Husky ones the bolt sticks out about half and inch above the nut.
This prevents the new leaf springs from resting flush with the bottom of the axle because the alignment hole isn't deep enough for this longer bolt.
I haven't really seen this problem mentioned before. Is the solution to just take a grinder to the centre bolt on the new leaf springs and cut it down so that it's flush with the bolt? If so, is there anything special to be aware of before cutting that bolt? I was planning to just cut it while it's holding the leaf springs together. It seems like asking for trouble to try and take the leaf springs apart, cut the bolt, then thread them back together.
Thoughts?
(Note, this isn't a lift kit or anything. I'm just swapping out cracked OEM leaf springs for these Husky ones.)
2000 Xterra XE V6
Husky leaf springs: 69-257 from Rock Auto
Husky U-Bolts: USB072R from Rock Auto
Reusing existing shackles and all other bolts.
Thoughts?
2000 Xterra XE V6
