oil leak - Nissan Xterra Forum: Xterra Forums
Old 02-07-2009, 04:21 PM
TIFFRO TIFFRO is offline
Member: #5261
TIFFRO is on a distinguished road
oil leak
Ok so I took my Xterra in for an oil change, got home and noticed about a 12 inch puddle of oil underneath, thinking they didn't tighten the drain bolt down I got underneath and noticed the oil steadily dripping from a hole. Here are some pics, give me your thoughts.
Old 02-07-2009, 07:21 PM
Member: #5261
they put 5 quarts of oil in also, is this too much?
Old 02-08-2009, 08:38 AM
dejablue's Avatar
dejablue dejablue is offline
Moderator
Member: #3797
2002&2003 Xterra
dejablue will become famous soon enoughdejablue will become famous soon enough
i put 5 qt in mine all the time. looks like rear main seal is leaking.
Old 02-08-2009, 10:09 AM
Drake's Avatar
Drake Drake is offline
Club Xterra O.G.
Member: #1986
Drake is a splendid one to beholdDrake is a splendid one to beholdDrake is a splendid one to beholdDrake is a splendid one to beholdDrake is a splendid one to beholdDrake is a splendid one to behold
I agree on the rear main seal. 5 quarts is too much for the 3.3L It's standard capacity is 3.5 quarts.
Drake's Build Thread
Old 02-08-2009, 11:27 AM
fisher93 fisher93 is offline
Member: #3858
fisher93 is on a distinguished road
The leak may be the oil pan gasket. I had a leak about two weeks ago took to my machanic and he said it was the pan gasket not the seal.
Old 02-09-2009, 02:52 AM
Ed-Terra's Avatar
Ed-Terra Ed-Terra is offline
Member: #4168
2008 X 4WD Xterra
Ed-Terra is on a distinguished road
Gen 2 takes 5.4 quarts (or something like that)
Sounds like the dummys read the wrong book for your X.
Lets hope the extra oil is just seeping out somrhow and didn't ruin the rear main seal!
I'd recommend not driving it untill you check the dip stick for over fill!
Old 02-12-2009, 05:18 PM
thumperpaul thumperpaul is offline
Member: #4478
2003 Xterra
thumperpaul is on a distinguished road
Sounds like they goofed, especially if you didn't have this problem before. My 2003 3.3L takes only 3.4L of oil, and judging from what was posted earlier, it sounds like some nimrod misread your truck as a second gen Xterra and overfilled the crankcase. (4.0L engine)
Drain off the excess before you blow some seals, and do the basic maintenance yourself. (VERY easy to do on the Xterra) To give you an example, when I first bought my X, I discovered that some idiot had filled the 5 spd transmission with ATF!!!! I only hope that I don't get any tranny problems down the road as a result of this.
If you do the basics on your truck yourself, you get to know it better...just my 2 cents...I won't trust my baby to some moron pump jockey!
  #8
Old 02-12-2009, 05:34 PM
Member: #5261
Yeah we called and informed them they overfilled it, he claimed that just because it says 5 qts on the paperwork doesn't mean they put that much in (yeah right) . Never had any trouble before the oil change and even after leaking out 3 10" puddles of oil the dipstick still showed too much oil. So he had us bring it back in so he could drain the oil to the right level and said if that didn't fix it to let him know and he would make it right.
After taking it back to him the dipstick shows no oil on it, I'm about to go out and take the drain plug off to see how much oil is in this thing. He also marked the oil cap and dipstick with red paint markers, what's the purpose of that?
  #9
Old 02-12-2009, 07:12 PM
Member: #4478
2003 Xterra
Like I said before, if you DIY, there's no worries....
  #10
Old 02-12-2009, 10:58 PM
buckethead47's Avatar
buckethead47 buckethead47 is offline
chicago fabricator
Member: #3382
buckethead47 is on a distinguished road
i would just drain whats in in and put new oil in it.
