2006 Xterra Fuel Sending Unit/Service Engine - Nissan Xterra Forum
post #1 of 11 Old 01-18-2009, 10:30 PM Thread Starter
lalande13
2006 Xterra
lalande13 is on a distinguished road
I have a 2006 Xterra and the fuel gage stopped working and it left my girlfreind stranded in -25 degree temp., for a hour till a cop came and picked her up. The history is when we fill it up it would go to E and the service engine light would come on, But after driving a litlbit it would go to full. i thought that the gas had moisture/ water in the tank and was freezing it up it was cold as f*ckl but it is now 40 degrees. Im wondering how to go about changing out the Sending Unit and not going to the dealer because they don't warrenty the fuel sending unit and they want to change out the whole assembly, pump, sending unit the whole nine yards costing about $600. Bullcrap. I Need a part number for the sending unit?and how to tare it down?I s their is a access port under the seat or the floor board ect.? Or do I need to pull the tank to access this rascal?
Thanks John
lalande13 is offline
2006 Xterra
post #2 of 11 Old 01-19-2009, 12:31 AM
Creepy Cruiser
I'm kinda wacko
Creepy Cruiser's Avatar
Quoted: 8 Post(s)
06 Zterra Xterra
Creepy Cruiser is a splendid one to behold Creepy Cruiser is a splendid one to behold Creepy Cruiser is a splendid one to behold Creepy Cruiser is a splendid one to behold Creepy Cruiser is a splendid one to behold Creepy Cruiser is a splendid one to behold Creepy Cruiser is a splendid one to behold
I'm pretty sure you have to drop the tank on that one, I'll see if I can find my info on it.
Creepy Cruiser is offline
06 Zterra Xterra
post #3 of 11 Old 01-19-2009, 12:40 AM
dezurtrat
Mindless Modding Moderator
dezurtrat's Avatar
Quoted: 4 Post(s)
2008 Xterra
dezurtrat is a glorious beacon of light dezurtrat is a glorious beacon of light dezurtrat is a glorious beacon of light dezurtrat is a glorious beacon of light dezurtrat is a glorious beacon of light
Yea, I believe you do have to drop the tank on the next Gens. BUT, Nissan has covered them under warranty in the past so unless you're out of warranty I'm sure it would be covered. Maybe the dealer is selling you a load of BS!
Also, I believe the sending unit (FSU) is separate from the fuel pump and I don't think its over $100 and I don't think dropping the tank on an '06 should be too bad.
dezurtrat is offline
2008 Xterra
post #4 of 11 Old 01-19-2009, 08:06 AM
Duke
Duke is on a distinguished road
After doing some research it appears many owners of the 2006, Xterra, Pathfinder and Frontier are having this same problem.
It seems GM and Nissan are buying the sensors from the same company.
If you are out of factory warranty, it is covered under the extended warranty Gold preferred plan.
I have also read reports where 2006 GM owners are having the same issue.
I find it strange that this part would fail so soon!
Also seeing it has a large across the board problem for so many owners, I ask the following:
Is it the same unit covered under the Nissan recall for 2001-2003 Xterras?
IE; same part that causes this problem?
If so, maybe Nissan did not make any changes it it carried over to later models?
Maybe this link will help you.
One guy explains how he got the dealer to fix it free.
Another tells how to get to it.
http://x.nissanhelp.com/forums/xterr...-unit-fix.html
Duke is offline
post #5 of 11 Old 01-19-2009, 08:20 AM
X_X_X
2006 Xterra
X_X_X is on a distinguished road
When I bought my '06 in Sept. of '08 the check engine light was on. They took it into the shop and and said it was the unit that tells you how much gas you have, and that it is a part that is under warranty (not that I was gonna pay for it anyway since I hadn't signed any papers yet to buy the X). They had to drop the tank to fix it, and after about an hour or so it was all done. Now sometimes when I get er filled up it takes a few minutes to register but it seems ok.
- Rob -
'06 - Black - OR - 6spd - no mods YET!
X_X_X is offline
2006 Xterra
post #6 of 11 Old 01-19-2009, 12:05 PM Thread Starter
lalande13
2006 Xterra
2001-2003 Recall
Well I have done some research also and they oly recalled for those years not 2005 to 2009 YET. they say that the cause is corosin just on the sending unit. not sure if it is were you plug it in or internaly. So i suspect that in another 40,000 miles i will need to replace it agen. Thanks for the support.
John
2006 Xterra
post #7 of 11 Old 01-19-2009, 12:12 PM
Cyclemut
Most Halal Mod
Quoted: 2 Post(s)
02 Xterra
Cyclemut has a spectacular aura about them Cyclemut has a spectacular aura about them Cyclemut has a spectacular aura about them
You have to drop the tank, it's not a corrosion issue and be very careful. Without taking your time to disconnect the lines properly, you'll be spending a whole lot more.
Cyclemut is offline
02 Xterra
post #8 of 11 Old 03-25-2010, 12:48 PM
Nexis619
2006 Xterra
Nexis619 is on a distinguished road
Nissan Finally recalled this issue.
Nissan just issued a recall for this problem: Ive spent a lot of time looking this up and it looks like my patience has paid off. Check out this link:
2006 Nissan Xterra FUEL SYSTEM, GASOLINE:STORAGE:AUXILLARY TANK Recall at Automotive.com
Here is the info:
Recall Date
MAR 03, 2010
Model Affected
2006 NISSAN XTERRA
Description
NISSAN IS RECALLING CERTAIN MODEL YEAR 2006 AND MODEL YEAR 2008 FRONTIER, XTERRA AND PATHFINDER VEHICLES. THE MOLDED FUEL TANK SHELLS CAN DEFORM, CAUSING THE FUEL SENDER FLOAT ARM TO CONTACT AN EMBOSSMENT MOLDED INTO THE TANK SHELL CAUSING THE INSTRUMENT PANEL FUEL GAUGE TO SHOW THAT THE VEHICLE HAS APPROXIMATELY ONE QUARTER TANK WHEN THE FUEL TANK IS EMPTY.
Consequence
THIS COULD CAUSE THE VEHICLE TO RUN OUT OF GAS AND STALL IN TRAFFIC, INCREASING THE RISK OF A CRASH.
Remedy
DEALERS WILL REPLACE THE FUEL LEVEL SENDING UNIT INSIDE THE FUEL TANK WITH A NEW ONE THAT HAS A MODIFIED FLOAT ARM. THIS SERVICE WILL BE PERFORMED FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR BEFORE MARCH 22, 2010. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Potential Units Affected
80689
Notes
NISSAN NORTH AMERICA, INC
Nexis619 is offline
2006 Xterra
post #9 of 11 Old 03-25-2010, 01:15 PM
soccerbrace
blah blah blah
soccerbrace's Avatar
Quoted: 1 Post(s)
soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold
X2-Go to Nissan with receipts.
Photobucket
soccerbrace is offline
post #10 of 11 Old 03-25-2010, 04:26 PM
Loki512
Loki512's Avatar
2009 S Xterra
Loki512 is on a distinguished road
(dunno if this has come up much on clubx, its a big issue on thenewx since those are 2nd gens) apparently Nissan is only set to recall 2006 and 2008 (not 05, 07,09 or 10). some guys are getting on the phones and emails to let nissan know this affects the 05 and 07 years too (i haven't heard anything about 08+ and it seems the sending unit was changed for those years) just FYI
Loki512 is offline
2009 S Xterra
