Bad Fuel Pump? - Nissan Xterra Forum
post #1 of 6 Old 12-03-2013, 06:23 AM Thread Starter
MTBSPEC
2003 Xterra
MTBSPEC is on a distinguished road
Bad Fuel Pump?
My 03 X - 3.3 116k needs me to turn the key to AC on and off a couple times to fully prime the fuel pump to start in cold weather. It starts fine in warm weather and it will sometimes start in the cold it will be just bog down before getting up to normal RPM's. The car justs fine. A previous owner has already had the recall with the fuel sending unit. Could this be a bad fuel pump or would i experience symptoms while driving?? or is this an electronic issue associated with the ignition?
Plugs, timing belt, fuel filter, fuel pressure regulator, coolant temp sensor, MAF sensor has all been recently serviced.
MTBSPEC is offline
2003 Xterra
post #2 of 6 Old 12-03-2013, 08:57 AM
Mogman
Mogman's Avatar
Quoted: 9 Post(s)
2011 Pro4X Xterra
Mogman Totally Rocks Mogman Totally Rocks Mogman Totally Rocks Mogman Totally Rocks
Garage
The fuel pump doesn't have any effect on your engine bogging down before getting up to normal RPMs during start (unless it's completely gone TU and you crank and crank until you kill your battery). An inop fuel pump means your X won't run. It's possible that you have a fuel leak somewhere, but my bet is your battery is toast. Cold weather will weaken the battery, especially if your electrolyte level is low. Weak battery and / or loose cables, which are very common problems on the Xterra, will make it hard to start, and even harder in cold weather. The battery cable clamps (even on the second gen) are absolute junk.
Go confidently in the direction of your dreams! Live the life you've imagined. As you simplify your life, the laws of the universe will be simpler. - Thoreau
Mogman is offline
2011 Pro4X Xterra
post #3 of 6 Old 12-03-2013, 11:30 AM Thread Starter
MTBSPEC
2003 Xterra
The thing is my battery is only about 18 months old and I got a new negative clamp at the same time. This is a problem I have been having since last winter - only in cold weather. The shop thought the fuel pressure regulator and coolant temperature sensor would solve the problem (luckily I was already getting a new knock sensor so the regulator didn't cost too much). It did help its tolerance of cold weather however when it dips below 32 it still really bogs down..... I am leaning towards a leak in the fuel line seeing how lately I have had success with priming the fuel pump a few times before starting....Could it be possible that this problem only manifests itself in cold weather though?
MTBSPEC is offline
2003 Xterra
post #4 of 6 Old 12-03-2013, 11:46 AM
Mogman
Mogman's Avatar
Quoted: 9 Post(s)
2011 Pro4X Xterra
Garage
Cold weather has a tendency to make poor electrical connections worse due to contracting metal. Check the other end of your battery connections for corrosion and security.
As I mentioned earlier: The fuel pump shouldn't need to be "primed" since it's in the fuel tank. Turning the key on is all you need to do. Turning it off then on won't help. If there is air in the line due to a leak it may take longer to get fuel up to the engine, but it has no effect on how fast your engine cranks during the starting procedure. Your engine should crank at the same speed regardless of the availability of fuel.
Mogman is offline
2011 Pro4X Xterra
post #5 of 6 Old 12-03-2013, 12:00 PM Thread Starter
MTBSPEC
2003 Xterra
the starter does turn it over just fine all of the time - when it fires up it bogs down badly and hovers around 500 RPM while feeling like it is missing for about 5 to 10 seconds before it seems to get it together and idle/run normally. This makes me think I need to check for leaks in the line.
Or possibly a bad check valve causing the gas in the line to leak back into the tank therefore taking more time to get gas in the lines
MTBSPEC is offline
2003 Xterra
post #6 of 6 Old 12-03-2013, 12:18 PM
Mogman
Mogman's Avatar
Quoted: 9 Post(s)
2011 Pro4X Xterra
Garage
OK that makes much more sense.
Mogman is offline
2011 Pro4X Xterra
