Headlight - Nissan Xterra Forum: Xterra Forums
Old 11-28-2008, 03:47 PM
twest2006's Avatar
twest2006 twest2006 is offline
Seasoned
Member: #3956
twest2006 is on a distinguished road
Headlight
Ok my headlight bulb on the passenger side is out. when i have my brights on tho it works or am i a dummy and its 2 different bulbs in there? i also wanna know how you change the bulb, if any of you recommend doin that first.
I'm in love.
Old 11-28-2008, 04:20 PM
john-k john-k is offline
Seasoned
Member: #392
john-k is on a distinguished road
its one bulb working as running low beam and high beam. the buld socket is easy to remove just twist it off. its right behind your headlight bucket.
2002 xterra v-6 s/c 4x4
2005 ktm450smr-race bike--sold
pimped out crf50!
Old 11-28-2008, 04:22 PM
TN4x4Xterra's Avatar
TN4x4Xterra TN4x4Xterra is offline
Moderator
Member: #3423
TN4x4Xterra is a jewel in the roughTN4x4Xterra is a jewel in the roughTN4x4Xterra is a jewel in the roughTN4x4Xterra is a jewel in the rough
x2 on john.
Its one bulb per headlight.
Simple to do...twist it off and swap it.
Old 11-28-2008, 04:39 PM
twest2006's Avatar
Seasoned
Member: #3956
not twistin. the manual told me to push down on a clamp or somethin and i dont see what its talkin about.
I'm in love.
Old 11-28-2008, 04:41 PM
Moderator
Member: #3423
Mine's a 2001 so it may be slightly different but when I swapped mine out, I had to twist it out.
Also, Check the headlight bulb FIRST before you go and replace it.
I got the bulb according to the manual and it did not fit, turns out it was a different bulb needed cuz when I looked in the burnt out bulb, it was totally different.
Old 11-28-2008, 05:44 PM
dantheman2702's Avatar
dantheman2702 dantheman2702 is offline
Member: #3719
dantheman2702 is on a distinguished road
First take off the wiring harness that is connected to the bulb, That is what the manual is talking about, then you should easily be able to twist the bulb out.
Old 11-28-2008, 06:48 PM
twest2006's Avatar
Seasoned
Member: #3956
oookk...after 2 hrs of agrivation finally got it. here's the story:
taking off the wiring harness-15 mins. there is absolutely no hand space where im working here.
taking off that other clamp. bout 30 mins. you gotta pull up on it and not push down. thnx xterra owner's guide. not! lol
taking the bulb out 2 secs.
new bulb in 45 min. i tried to push it in for about 10 mins, then i called a friend to come help and he couldnt get it in either. Stay with me people, no gutter minds. lol. so we started comparing the bulbs almost identical. one difference. the bulb i NEEDED was a 9004 and the bulb the autozone guy said i needed was a 9007. the 9007 is about 1cm too wide. go back to autozone go home and in no longer than 30 secs. light's in and clamp on, and harness connected. and i got lights. it was dark and rainin too. i also found a spare oil cap. must be from the previous owner cuzz i havent lost mine.
I'm in love.
  #8
Old 11-28-2008, 08:37 PM
Moderator
Member: #3423
Yeah I had that issue with the bulb size.
Glad you got it working now.
  #9
Old 11-30-2008, 08:03 AM
k1w1t1m's Avatar
k1w1t1m k1w1t1m is offline
Kiwi Bloke
Member: #1778
k1w1t1m has a spectacular aura about themk1w1t1m has a spectacular aura about themk1w1t1m has a spectacular aura about them
Glad you got it sorted.
96 TLC
http://www.supermotors.net/vehicles/registry/15556
http://www.supermotors.net/vehicles/registry/17906
Don't steal, the government hates competition.
  #10
Old 02-11-2009, 07:50 AM
platanojavid's Avatar
platanojavid platanojavid is offline
Member: #2666
platanojavid is on a distinguished road
how about adjust a headlight i got mine my headlights restored and i guess they kinda pushed the driver side down some so how can i get the beam up a lil higher so it matches the passenger side i searched the forum but found nothing
"Once a Nissan Driver Always a Nissan Driver"
