coolant drain - Nissan Xterra Forum
post #1 of 22 Old 11-24-2008, 12:14 AM Thread Starter
phrog man
Chrome can go to hell
phrog man's Avatar
Quoted: 1 Post(s)
phrog man will become famous soon enough
coolant drain
hey guys, more maint. how would i drain the coolant fliud on a 1st gen, the fluid looks a little too dark for my liking. has any one flushed theirs before, is there some kind of drain cap on the bottom of the radiator or something?
phrog man is offline
post #2 of 22 Old 11-24-2008, 12:31 AM
soccerbrace
blah blah blah
soccerbrace's Avatar
Quoted: 1 Post(s)
soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold soccerbrace is a splendid one to behold
Should be a petcock on the bottom of the radiator.
Photobucket
soccerbrace is offline
post #3 of 22 Old 11-24-2008, 07:02 AM
baf6
Spaz
baf6's Avatar
baf6 Totally Rocks baf6 Totally Rocks baf6 Totally Rocks baf6 Totally Rocks
yea, there is a small plug at the bottom of the radiator...if you are doing a full flush, there are also 2 plugs on the block itself, one on either side, below the exhaust manifolds....pick up a haynes manual and it will show you where they are...
or, an easier method is to drain the radiator, refill with water, start the truck and let it reach temp and hold it for a few minutes, then turn off, let cool, and drain again....takes longer, but it works when those drain plugs are being a bitch
baf6 is offline
post #4 of 22 Old 11-24-2008, 10:54 AM Thread Starter
phrog man
phrog man's Avatar
Quoted: 1 Post(s)
thanks guys thats all i needed to know, nice info baf6. i think shes up for a full flush.
post #5 of 22 Old 11-24-2008, 12:01 PM
baf6
Spaz
baf6's Avatar
no problem....word of advice though, when you locate those plugs on the block, spray them down with PB a few days before the flush...mine refused to budge, so i ended up going the ghetto "flush,fill,repeat" method....if you need, i can send you pics of the drain plugs
also, dont forget the antifreeze! dont get the 50/50 mix, this time of year you should really be running a little more antifreeze than water, so get the regular stuff and mix it yourself about 60/40 (antifreeze to water).....then in the spring/summer, drain out a few quarts, replace with water, and toss in some "water wetter"(really does work, a notice i run about 3 needle's widths cooler according to the temp gauge)
baf6 is offline
post #6 of 22 Old 11-24-2008, 12:05 PM
Xterra Mike
Silver Submarine
Xterra Mike's Avatar
Quoted: 13 Post(s)
2001 SE Xterra
Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough Xterra Mike is a jewel in the rough
Garage
yea post some pics. I would like to see the drain plugs
Xterra Mike is offline
2001 SE Xterra
post #7 of 22 Old 11-24-2008, 12:09 PM
baf6
Spaz
baf6's Avatar
ok, ill scan them right from the haynes manual later after work
baf6 is offline
post #8 of 22 Old 11-24-2008, 12:14 PM
Xterra Mike
Silver Submarine
Quoted: 13 Post(s)
2001 SE Xterra
Garage
are they in the Chilton Manual too?? i have that one.
2001 SE Xterra
post #9 of 22 Old 11-24-2008, 12:18 PM
baf6
Spaz
baf6's Avatar
most likely, look in the general maintenance section...haynes had a pic of them, chilton might just describe the location
baf6 is offline
post #10 of 22 Old 11-24-2008, 12:25 PM
baf6
Spaz
baf6's Avatar
plug location shown(kind of)...its labeled PLUG 1(08931-3021A), other side is (08931-3041A)...i believe both are 14MM bolts
ill post the exact location later
baf6 is offline
