check engine light! - Nissan Xterra Forum
post #1 of 4 Old 09-25-2008, 12:19 PM Thread Starter
Robert96782
2005 Xterra
Robert96782 is on a distinguished road
check engine light!
I just saw that my check engine light came on and not sure what that means or need to do. someone told me that this can happen if gas cap in not on properly. I checked this and the light is still on.
what can i do.
Robert96782 is offline
2005 Xterra
post #2 of 4 Old 09-25-2008, 12:31 PM
Keyz18
Unlocking Potential
Keyz18's Avatar
2007 OR Xterra
Keyz18 has a spectacular aura about them Keyz18 has a spectacular aura about them
Remember, the check engine light only comes on when your emissions are not regular. This is why when your gas cap is screwed in wrong, the light comes on. Note: That the engine light will continue to be on, even after you fix the gas cap. Mine didn't go off till I drove around 30 miles.
I also had the light turn on after I installed a new intake. The air calibration sensor came undone. You may want to check that as well.
2007 Off Road Night Armor KEYZ EDITION
Keyz18 is offline
2007 OR Xterra
post #3 of 4 Old 09-25-2008, 01:12 PM
silverbullet
ASE Certified
silverbullet's Avatar
Quoted: 1 Post(s)
silverbullet will become famous soon enough silverbullet will become famous soon enough
it comes on solid when emissions or problem related to the vehicle. if it flasshes at your pull over because whatever is triggering it to flash is usually detrimental to the engine if you continue to drive it. It could be a loose gas cap. unscrew it and put it back on tight. If it stays on after 30 or so miles or 7 or more starts its not the gas cap mostlikely unless the gascap itself isnt holding the pressure in the tank and its letting pressure escape in which case it would need to be replaced. Take your X to autozone, advanced, oreillys or another autoparts store and have the codes read and let us know what it says. check your vacuum hoses going to and from the intake too. one may have com loose but 99% of the time a solid MIL light is due to an emissions problem
silverbullet is offline
post #4 of 4 Old 10-01-2008, 07:26 PM
k1w1t1m
Kiwi Bloke
k1w1t1m's Avatar
k1w1t1m has a spectacular aura about them k1w1t1m has a spectacular aura about them k1w1t1m has a spectacular aura about them
Take it to Autozone or somewhere similar and have the codes read. Report back here with the findings and we might be able to help.
k1w1t1m is offline
