p0505 and p0325 codes - Nissan Xterra Forum
post #1 of 5 Old 07-17-2013, 01:58 PM Thread Starter
x01sd
I keep having the p0505 and p0325 codes come up on the scanner. It happened right after I replaced the driver side valve cover gasket. The truck runs and idles perfect, no problems at all-ZERO, but I live in cali and it won't pass smog with the ses light on. I've read a few posts on the topic, but no luck.
Things done:
Idle air volume learning (idle was fine before, still ok)
Check timing - ok
Clean MAF sensor
Clean throttle body
Check plugs/connectors
New sparkplugs
It's a 2001 v6 4x4
x01sd is offline
post #2 of 5 Old 07-17-2013, 03:25 PM
jhill15
jhill15's Avatar
Quoted: 7 Post(s)
I don't know if this will help and you may have already been to this website but here is what I found based on the codes.
http://www.obd-codes.com/p0325
http://www.obd-codes.com/p0505
Hope this will help any
jhill15 is offline
post #3 of 5 Old 07-17-2013, 06:27 PM
jugrnot
jugrnot's Avatar
2003 Xterra
the knock sensor does not turn the CEL on . It will show if you scan so that might have been bad for a while. I would say the area of attack would be the 0505 code.
However I did just replace the KS on the X this weekend runs a lot better. No pinging when going up hill. Step on the gas she goes. I would not pay a shop to do the job but if you do not feel mechanically inclined dont worry about. Again attack the 0505 code.
jugrnot is offline
2003 Xterra
post #4 of 5 Old 07-18-2013, 12:00 AM Thread Starter
x01sd
Not worried about the knock sensor as much as trying to clear the p0505 code. Thanks for the links, i've read them before. I have checked everything but the pcm. How do I go about removing it ?
x01sd is offline
post #5 of 5 Old 07-19-2013, 07:50 PM
jugrnot
jugrnot's Avatar
2003 Xterra
My X is 03 but the inside should be the same. PCM is located under the radio on the floor board. Start with center console. If memory serves me right start at the back. Screws are by the back of the driver and passenger seats. From there follow the screws. I believe that you will have to remove the radio ( at least for me I would). From there the pcm is the silver box bolted to the floor board.
Just a side note you said that is happen after replacing the driver side valve covers. the plugs (connectors) for the throttle position sensor ( on the throttle body ) are plugged nice in tight or maybe this sensor could be bad ... Just a thought.
jugrnot is offline
2003 Xterra
