Aftermarket Stereo install?? - Nissan Xterra Forum
post #1 of 4 Old 06-05-2008, 03:12 PM Thread Starter
V6XterraGirl
V6XterraGirl's Avatar
V6XterraGirl is on a distinguished road
Question Aftermarket Stereo install??
I am sure this has been asked before... but I am new. ;-)
I have a 2002 Xterra with the single disk factory CD player in it. I just bought a new JVC HD CD player I want to install.
How do you get the factory one out? Also, tips on installing the new one would also be great!
Thank you so much!!
V6XterraGirl is offline
post #2 of 4 Old 06-05-2008, 03:31 PM
Ricer-X
WHO DAT
Ricer-X's Avatar
Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of Ricer-X has much to be proud of
OK
TO REMOVE THE CENTER CONSOL where the radio is there are screws on the underside of stuff, the lil ledge uder the radio, the ledge under the temp controls, etc, remove all those screws and the whole thing just pops off(pull near the top
then you will have to remove the consol part by the shifter to get the control part all the way off(should be pretty straight forward once you get the first piece off)
then make sure you have a wire harness so you dont have to cut any wires and you will need a lil double din thing to make up for the space since the new one prob only takes 1/2 the space of the stocker
then plug it in and bolt it up
Dustin - 2004 XE V6 2wd; 3" SL, 2" BL, 33x12.5" ATs, HooHaa Steering, Idler arm Brace, 5% tint, Bilstein HD shocks, SAW Tbars, 1/2" ball joint spacers, piaa, HD Tbar anchors, B&M Tranny Cooler Stock Intake Mod, blacked out plastics/wheels/rack
Ricer-X is offline
post #3 of 4 Old 06-05-2008, 04:07 PM Thread Starter
V6XterraGirl
Cool that doesnt sound too bad! Thanks!
I did buy a install kit and wire harness for it. :-)
post #4 of 4 Old 06-05-2008, 04:49 PM
Brett89
Brett89's Avatar
Brett89 is on a distinguished road
http://www.clubxterra.org/forums/showthread.php?t=2986
Great little how to there, it's very easy though, good luck with yours.
The plugins can be finicky, there are three tabs you need to push to take them out one on top and two on the sides.
2002 Xterra 5 speed manual V6 4X4
Brett89 is offline
