Help! - Nissan Xterra Forum: Xterra Forums
Old 02-26-2013, 01:57 PM
jmac212 jmac212 is offline
Member: #35116
2010 Xterra
jmac212 is on a distinguished road
Help!
My 2010 X makes a clunk sound when I hit bumps going about 25-30 mph. The noise comes from the passanger front. Any ideas what it could be?
Old 02-26-2013, 02:10 PM
TJTJ's Avatar
TJTJ TJTJ is offline
Member: #374
TJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to behold
Talking
Lots of possible things...the most common is the hood cushions/stops needing adjustment....followed by the shock mounts getting loose, etc.
After that, there's so many things to clunk on any given truck...we'd need more info.
Are you able to recreate the clunk in the driveway, by bouncing the rig, or shacking the hood or shocks, etc?
Can you jack up the front, and shake the tires in/out from both top/bottom grips and f/r grips?
-TJ
Old 02-26-2013, 04:48 PM
Member: #35116
2010 Xterra
jacked it up and tried shacking the tires, didn't really move.... it kinda sounds like the noise comes from the cv axles but thats just what I hear while driving.
