winch options - Nissan Xterra Forum: Xterra Forums
Old 02-24-2013, 06:25 PM
RebelChief RebelChief is offline
Member: #38117
2003 Xterra
RebelChief is on a distinguished road
winch options
I have not seen a thread about winches and I wanted to see everyone's opinion and advice on buying a winch. I have a 2wd and I can't take on hard trails but Iv been stuck and I can get stuck easier than a 4wd so I wanna get one to self recover. Thanks for input.
Old 02-24-2013, 07:13 PM
dmski's Avatar
dmski dmski is offline
Member: #37695
dmski is on a distinguished road
Lots of info around. Warn is highly respected, but be aware that you need a place to mount your winch. Best options are winch bumpers (Schrock, etc) but some have been able to fab up winch mount plates that can be bolted/welded to the frame. If your looking to buy a winch, there is a lot of other equipment to remember.
In my opinion, unless your offroading a ton alone, I wouldn't worry too much about a winch and just go with buddies who can pull you out. More fun with friends too!
2000 Xterra XE 5-spd
  • [X] Light Bar with 4 Hella Lights
  • [X] CB/Firestick Install
  • [ ] Relocate Rear Axle Breather
  • [ ] Lobo Rack
  • [ ] Seafoam
  • [X] Mudflap/sidesteps delete
  • [X] Window Vinyl
  • [X] Front Tow Hook Replace
  • [ ] Tow Hitch Install
  • [ ] Rock Sliders
  • [ ] PML
Old 02-24-2013, 07:31 PM
Member: #38117
2003 Xterra
I mostly go camping and exploring the deserts of southern California but it's mostly with just my girlfriend so I need to have a method to get us out. A bumper is already on the way. Just wanted to know if the bargain winches were a good affordable option. If seen a few 8k lbs for like 300.
Old 02-24-2013, 08:24 PM
Xterror04's Avatar
Xterror04 Xterror04 is offline
Member: #8609
Xterror04 is a jewel in the roughXterror04 is a jewel in the roughXterror04 is a jewel in the roughXterror04 is a jewel in the rough
I have a harbor frieght winch, it has pulled myself and friends out time and time again, it's slower then most but still works great... Whenever I'm stuck Ill winch my self out over being pulled anytime much easier to control the situation
Build Thread
Old 02-24-2013, 11:27 PM
Member: #38117
2003 Xterra
yeah i get what you mean and i was looking at the harbor freight winches but wasnt sure if it was too good to be true. iv been lucky enough to be saved by a few jeeps on some trails but i hate depending on others especially if i can get myself out. by the way great Xterra i love your build!!
Old 02-25-2013, 01:05 AM
Member: #38117
2003 Xterra
i guess the main point of this is to find out whats the minimum lbs rating, what gear ratios, what type of winch (if there is different types) i just need to be better educated on winches so i can make a good decision.
Old 02-25-2013, 06:32 AM
robcarync's Avatar
Member: #33023
I wouldn't mind hearing a few others chime on on this either...now that I have a winch bumper I find myself looking around...
2004 Xterra 4X4
To Do
Building my X
  #8
Old 02-25-2013, 07:49 AM
SamsXE's Avatar
SamsXE SamsXE is offline
Member: #33065
I read an article about a couple that drove a land rover across Africa. It was a pretty capable machine but it had no winch and they tackled some pretty gnarly terrain.
The man made a comment that "stuck" with me it went something along the lines of how you are more willing to tackle an obstacle outside your equipment (or your own) capability than you normally would. Then you start getting dependent on the winch and the one time it fails will probably be when you are really stuck...
But I will admit it has a cool-factor and I still want one haha
My Build Thread:
  #9
Old 02-25-2013, 08:31 AM
robcarync's Avatar
Member: #33023
I'd agree with that some...I would definitely be willing to try some harder terrain knowing that I have the winch safety net...but trying something outside of your comfort zone isn't necessarily bad...it's how you get better and learn more as long as you are being careful.
I never really had a plan to get a winch, I've never needed one thus far. But I figure since I have the winch bumper now, it wouldn't hurt to get one. I'd probably go with a cheaper harbor freight type of deal...I don't offroad enough to justify 500+ dollars for a winch. Not sure what kind of strength rating etc I would need for one though. Haven't heard a lot about them
2004 Xterra 4X4
To Do
Building my X
  #10
Old 02-25-2013, 09:10 AM
Xterror04's Avatar
Member: #8609
The minimum weight you want is 8k the general rule is vehicle weight times 1.5....also it depends on your terrain rocks and suck 8k is good... If you get bogged down with mud and have lots of areas where the vehicle can sink you will want more pulling power like a 10k....
The smitty built x20 winches are a great bang for your buck as well....
Nothing will beat the price point of a harbor frieght badlands winch though... It can be had for around $280 with a 20% off coupon and for $20 can be made witless with a remote
Build Thread
Tags
options, winch
