12V output in dash not working - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Nissan Xterra Mods > Interior Mods
Old 02-24-2013, 01:53 PM
shu2kill shu2kill is offline
Member: #38746
shu2kill is on a distinguished road
hey. i have a 2002 Xterra, and, my dash 12V output is not working. i tried plugging my iphone charger, but it didnt work. so, while installing a stereo, i checked voltage on the wires and i dont have any.
do you know if there is a fuse i should look for?? or what can be the problem?? i would like to fix it so i can plug my iphone there...
thank you!
Old 02-24-2013, 02:49 PM
robcarync's Avatar
Member: #33023
should be...i believe a 15 amp fuse in the little fuse panel in the dash on the drivers side...between the door and the steering wheel...
there should be a fuse diagram on the backside of the panel...if not I think I have one somewhere around here. Either way, I ended up figuring it out by just checking all the fuses...the one thats broken...probably is your problem
2004 Xterra 4X4
To Do
Building my X
Old 02-24-2013, 05:00 PM
GhettoMedic's Avatar
GhettoMedic GhettoMedic is online now
Seasoned
Member: #29542
GhettoMedic is on a distinguished road
Yup, I had the same issue. It has its own fuse in that dash panel. 1/2 way down and to the right.
GhettoMedic (Dave)
Ashland, MA
Blue 2004 Xterra
Auto Trans
4WD
www.DavidsPhotography.Smugmug.com
Old 02-25-2013, 09:05 AM
Member: #38746
thanx!! ill take a look at the fuse box tonight...
Old 02-25-2013, 09:39 AM
mjepps72's Avatar
mjepps72 mjepps72 is offline
AZ Mike
Member: #38467
mjepps72 is on a distinguished road
Same problem, same fuse
Mike
Mesa, Arizona
2004 Nissan Xterra XE
3.3L V6 RWD
Silver
