07 Xterra approaching 100,000 miles - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Tech Talk > Scheduled or Preventive Maintenance
Old 02-23-2013, 08:01 PM
shane_sd shane_sd is offline
Member: #32460
2007 Xterra
shane_sd is on a distinguished road
Exclamation 07 Xterra approaching 100,000 miles
My wife's 07 xterra is coming up on 100,000 miles (she bought it new, what a rock solid car btw), and I wanted to hear from the experts here on what should be done or looked at.
We just had the shocks done, brakes, and had a new battery put in. Any suggestions or advice would be much appreciated! Thanks guys/gals.
Old 02-24-2013, 06:51 PM
Member: #32460
2007 Xterra
Any preventative care I should be taking? I read something about a transmission problem on the second gen's?
Old 02-24-2013, 10:19 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
That would be SMOD (Strawberry Milkshake of Death) take a look through this thread. http://www.thenewx.org/forum/showthread.php?t=36132
Old 02-25-2013, 11:59 AM
xterractivities xterractivities is offline
Member: #39282
2006 Xterra
xterractivities is on a distinguished road
My X just turned 100.095 and I changed the Transfer case oil (used Mercon III) and now changing the rear differential (wish me luck) to be 80w-90.
So, have all differential oil changed (if a 4wd you have a front dif; rear dif; and transfer case.
Live well. Drive well. Enjoy life.
Old 04-16-2013, 08:59 AM
Tzupp86 Tzupp86 is offline
Member: #44865
2006 Xterra
Tzupp86 is on a distinguished road
Just bought my '06 4x4 Xterra... Love it.
Wondering what I should be doing as well. I'm about to break 90k. Also planning a road trip in a month or so....
Old 04-16-2013, 06:18 PM
kms1990's Avatar
kms1990 kms1990 is offline
Member: #34507
change tranny fluid, coolant flush, have water pump checked. check the serpentine belts, new spark plugs and have coils checked, run some lucas fuel treatment through the tank. change diff fluid, and power steering fluid, have brake fluid (and brakes themselves)checked. new air filter wouldnt hurt. clean mass airflow sensor and throttle body. just the basic stuff. some may have been done at earlier time and not needed now (check maintenance records to verify)
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
