First gen x with pml sitting crooked? - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Offroad Modifications 1st gen (00-04) > Offroad Suspension & Steering
Old 02-17-2013, 07:16 AM
blackx09's Avatar
blackx09 blackx09 is offline
Member: #30642
blackx09 is on a distinguished road
Hey guys I need help I don't know what's going on with my x but I'm hoping someone can chime in here. I have a 1st gen with a pml using ac shackles and obvious tb crank. My problem is that over time my passenger side has damn near returned to stock height while the driver side has retained the same lift it had. Anyone have any idea what the hell is going on here. It's the whole passenger side front and rear that has dropped. At first I was thinking maybe the tb on that side loosened up but I checked it and all is well. I'm at a loss here and really want to fix it because it looks stupid lol. Ill try to snap a pic of it when I get out of work.
Sent from AutoGuide.com App
Old 02-17-2013, 09:53 AM
blackx09's Avatar
Member: #30642
Ok so here's a pic I dot know how well you can see it but maybe this will help someone
Old 02-17-2013, 03:14 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Are the bump stop gaps the same left to right?
Old 02-17-2013, 03:36 PM
blackx09's Avatar
Member: #30642
That I don't know ill have to check later when I get home
Old 02-17-2013, 05:46 PM
Xterra Mike's Avatar
Xterra Mike Xterra Mike is offline
Silver Submarine
Member: #2784
2001 SE Xterra
Xterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the rough
Time for a readjustment. My pass side is a little lower too.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
http://www.clubxterra.org/forums/sho...terra+mike%27s
Fan Club:
http://www.facebook.com/group.php?gid=118570174822483
Old 02-17-2013, 06:07 PM
blackx09's Avatar
Member: #30642
Is yours the whole passenger side or just the front.
Old 02-18-2013, 06:02 PM
Silver Submarine
Member: #2784
2001 SE Xterra
The front. If your low in the front it will make it look low in the back too.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
Fan Club:
  #8
Old 02-18-2013, 06:44 PM
robcarync's Avatar
Member: #33023
Front torsion bar adjustments will change ride heights on all 4 corners as it changes the weight distribution.
If your t bars drop the lift...its one of 3 things:
Either your bars sagged...and you need to compensate for them...
The bolt is somehow unscrewing, allowing the adjustment to slip out
your bolts are secure but your splines are stripped, allowing the bar to slip in the anchors.
I would start by adjusting your pass side again to the right bump stop gap...and use a paint pen to mark your t bar to your adjuster finger/anchor...and a mark above the two nuts on the bolt...
If it sags again...see if the lines are in the same spot....if your anchor splines are still aligned, you know your anchors are gripping the splines right. If the mark on the bolt is in the same spot (say...1/2" above were your lock nut was, etc) then you know your bolt is in the same location. If both of those are good...then you know the rotation is coming from the torsion bar itself and its simply losing stiffness.
Also...make sure you have even tire pressure/tread on all 4 corners...that will kinda screw with your height measurements too
2004 Xterra 4X4
To Do
Building my X
