Whats this on my intake? - Nissan Xterra Forum: Xterra Forums
Old 02-16-2013, 01:04 PM
sdubking sdubking is offline
Member: #39214
2003 Xterra
sdubking is on a distinguished road
Hello all. First timer here. I just bought a used 03 from a "new car dealer" So when I was under the hood at the dealer I missed this thing hanging off the intake tube.
Other than this thing, this truck has been great, I just fixed the oil leak coming from the loose passenger valve cover and I have been enjoying the ride.
Oh yeah, is there an inspection hole for the timing belt on the 3.0?
ID:	9529   Click image for larger version
Old 02-16-2013, 01:24 PM
dezurtrat's Avatar
dezurtrat dezurtrat is offline
Mindless Modding Moderator
Member: #2413
2008 Xterra
dezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of lightdezurtrat is a glorious beacon of light
WOW, that's messed up! I would drive back there and ask them about it and suggest they replace it with an intake without the extra hole. Looks like they jerry rigged a way to plug that hole.
Welcome to CX!
Old 02-16-2013, 01:28 PM
Member: #39214
2003 Xterra
Right? I think I will just take the tube out and put some duck tape over the hole. I have a feeling someone was trying to get this to pass smog and had some crazy idea? no idea.. that tube is all sealed/glued up so, I am not sure.
Old 02-16-2013, 02:15 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
I have no idea what they were doing there as that is an intake resonator. Most of us have removed them from our trucks and blocked off the holes. http://www.clubxterra.org/forums/showthread.php?t=2192
There is no inspection hole for the timing belt on the VG33 (3.3L) engines.
Old 02-16-2013, 04:24 PM
xtacular's Avatar
xtacular xtacular is offline
Member: #13879
Maybe part of a HHO setup?
2002 Super Black 5 Speed 4x4
Shovel Mount
Old 02-16-2013, 04:49 PM
Gingerbloke's Avatar
Gingerbloke Gingerbloke is offline
Member: #38505
Gingerbloke is on a distinguished road
That is one gypsy-built looking setup. I would definately go over the rest of it with a fine tooth comb - and there are new plug wires too...monkeying with emissions?
Hmmmm....a mystery. Hope it has a happy ending!
Coming soon:
[ ] Body trim paint
[X] mud flaps removed
[X] new tires
[ ] Bilsteins all around
[X] Resonator delete
[ ] PML W/UCA and upgraded torsion bars
[ ] HID Hi/Lo kit
[ ] Roof rack
[ ] Quest alternator
[ ] 02 S/C radiator swap
KCCO!
Old 02-16-2013, 04:53 PM
Member: #39214
2003 Xterra
Errr... after some HHO on the Googles... this might be what the previous owner was doing. I noticed some missing bolt on the resonator, and a missing bolt on the air box. Also judging by the hose clamps, the tubes that lead off to the valve covers have recently been tampered with. Well since I am in CA I wont be able to remove or alter any of the intake components due to SMOG inspection. I will have to pickup a new resonator or just black duct tape it closed.
Thanks for your help guys.
  #8
Old 02-16-2013, 06:03 PM
miskywhisky miskywhisky is offline
Member: #9010
miskywhisky will become famous soon enoughmiskywhisky will become famous soon enough
Looks like your brake fluid needs to be bled too. Kind of dark.
  #9
Old 02-16-2013, 08:23 PM
cbxterra cbxterra is offline
Member: #18847
shame you can't do what all of us non Californians do. One plumbing plug and remove the resonator completely. [check the DIY on how to get the most out of your stock intake if curious]
  #10
Old 02-16-2013, 09:15 PM
Itsme's Avatar
Itsme Itsme is offline
Member: #16990
2000 4x4 Xterra
I am guessing they were injecting alcohol, in an attempt to pass smog... It is dumb looking and done by some freakish person!
Itsme
2000 X SE
