Rough idle, Then Shut down - Nissan Xterra Forum: Xterra Forums
Old 02-16-2013, 05:24 AM
JPR1209 JPR1209 is offline
Member: #38945
JPR1209 is on a distinguished road
I have a '02 X S/C the other week my wife was driving the X and it died on her after shuttering at a stop light. I went to check it out and noticed that the #5 ignition wire boot had been chewed on ( acorn where everywhere also) and the bracket was exposed. We got it back to the house. I changed out the ignition wires and still runs rough when in gear then dies. I had the distr cap ignition wires and plugs all replaced 20,000 mi ago. As well as the timing belt and fuel system, exhaust manifolds and gaskets and trans flush. Took it to autozone no code has been thrown and the MIL has not come on. At a lost for ideas on what the issue is. I did wonder if the could be excess gas stopping the #5 plug from firing correctly. It does drive for about an 1/8th mi before i have to shut it down or let it die. Any help would be appreciated.
Old 02-16-2013, 07:06 AM
iwashmycar's Avatar
iwashmycar iwashmycar is offline
Member: #31171
2003 Xterra
iwashmycar is on a distinguished road
I would bet other things got chewed, but have no guesses as to what. Did you replace all of the wires?
-Adam
2003 Nissan Xterra XE 2WD AT
2007 (O|TOYOTA|O) FJ Cruiser 4WD AT
Old 02-16-2013, 07:22 AM
Member: #38945
chewed
Yes I changed the rest of the wires as well as the chewed one. From what I can see nothing else has been chewed on or worn out. I have looked all around the engine top, bottom and side to side with wheels removed. I am going to change to rest of the spark plugs. then see if that helps.
Old 02-16-2013, 09:18 AM
kms1990's Avatar
kms1990 kms1990 is offline
Member: #34507
check the wires that plug into the distributor to give it power follow them all the way back to where they run, they may have gotten chewed on. check your battery ground cable at its ground point on the frame and all grounds that run to engine block. but any wire could have gotten chewed and screw the whole truck up.
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
Old 02-17-2013, 04:42 AM
Member: #38945
Haha
Well thanks for the advice but i found the problem. There was acorn debris around the plug. So my guess is the ignition wire i replaced was never sitting on the plug correctly. So today I am going to remove the supercharger and see if I can't see it better and get in there to clear the debris. Again thanks for all the advice I will update with any other info.
Old 02-17-2013, 06:12 PM
Gingerbloke's Avatar
Gingerbloke Gingerbloke is offline
Member: #38505
Gingerbloke is on a distinguished road
Stupid acorns.
Coming soon:
[ ] Body trim paint
[X] mud flaps removed
[X] new tires
[ ] Bilsteins all around
[X] Resonator delete
[ ] PML W/UCA and upgraded torsion bars
[ ] HID Hi/Lo kit
[ ] Roof rack
[ ] Quest alternator
[ ] 02 S/C radiator swap
KCCO!
Old 02-26-2013, 02:03 PM
Member: #38945
ok still runs rough
Well I guess I did not solve the problem. I replaced all of the spark plugs after cleaning all of the acorn mess up. Check to make sure all plugs were tight and wires snug and tightly connected to the plugs. put my S/C intake back on and she ran fine. All day sunday drove around 3 times for first for 10min the 15 min then ran a few errand s 30 min. Wife dorve it to work Monday and it was fine till she was about a block away. I tried to drive it home but kept stalling. It would not let me get the rpms past 2k. and when I stomped on it the rpms dropped. Finally I gave up. I disconnected the battery and reset it. I am going to try and get it home tonight when I pick up the misses. any help is appreciated if anyone is still listening.
  #8
Old 02-26-2013, 03:23 PM
SamsXE's Avatar
SamsXE SamsXE is offline
Member: #33065
Um check inside the intake box. Like you may have sucked a squirrel up in the intake...fur and acorn junk tends to mess up the MAF sensor readings...
TAKE PICS OF WHAT YOU FIND IN THERE!!!
My Build Thread:
  #9
Old 02-26-2013, 05:42 PM
Member: #38945
Today's drive
I took apart the air intake, when I changed out the spark plugs and checked for any clogs. I am going to clean the MAF as soon as I get it home.
I tried to drive the rest of the way home today and made almost there, till it just stalled and would not go anymore. The rpms were fluctuating between 500 and 2000 the whole drive and had to let it coast above idle most of the way. It stalled every time I had to stop at a light. To get it going I would start it the put it drive and hit the accelerator as fast as possible. Thinking that the problem is the distributor.
  #10
Old 02-27-2013, 10:05 AM
iwashmycar's Avatar
Member: #31171
2003 Xterra
Sounds very likely
-Adam
