The hook would be easy - because it has such a long twist on it, I could quickly put a recovery strap on it without worrying (too much) about it slipping off.
The eye...I'm not sure what the benefit is. I would need a strap and a D-ring, which would make it more secure = safer. Is there any other added benefit to this thing?
- Brian (Jack)
| 2002 3.3L 4x4 XE - the Terradactyl |
[x] K&N filter, rear sway bar & side rail removal, repaint trim
[ ] Gobi ladder and low-profile rack
[x] BFG Rugged Terrains
[x] Front & rear recovery points, LOBO, PML
[ ] Xoskel lightbar & PIAA lights, Mean Green alternator
[ ] Full armor - skid plates & sliders, hidden winch
[ ] IAB, Bilsteins, HD TRAs
[ ] Low-profile snorkel, CB installation
Between the too, I'd get the hook...it is faster/easier to get a strap over it, etc.
I have D shackles, hooks, etc...and I prefer the hooks 90% of the time.
The D Shackles are more secure if the pull is off angle and/or the terrain will potentially knock/pull the strap from a hook, say by going slack and then picking up again, etc.
If you can only have one, the receiver shackle set ups shown work well in all scenarios, but it is a bit slower to undo the shackle, insert the loop, screw the bolt back in, etc.
A factor that is not an issue in some places, and is in others, is theft.
The hook in the receiver can use a locking pin, but the D Shackle in the receiver can't, so, a determined passer-by can unscrew the shackle bolt and take the shackle itself.
I use both, so I have two shackles and a hook out back.
Location: Surrounded by Jeeps in an Xterra-less Michigan
Member: #33519
I never thought about the angled pull. Thanks for the heads up.
And honestly, every time I get back into my truck, the first thing I do is check to see if my shackle is still there. Theft isn't really a huge issue, but still...
Thanks, TJTJ. As always, you're the man!
- Brian (Jack)
