Stripped timing belt.. - Nissan Xterra Forum: Xterra Forums
Old 01-29-2013, 07:56 AM
VTxter VTxter is offline
Member: #38848
VTxter is on a distinguished road
Driving my xterra from to walmart in richmond, and instantly quits going up a small incline. Try to start it again and nothing but an increased rpm crank. No fire. I spend two hours trouble shooting and eventually come to the realization that my timing belt has broke or the gear on the camshaft has been sheared. I had to walk home at 12 at night in 15 degree weather. My x has 198000 miles on it. I bought it assuming that at 188000 miles it had been changed at some point around 100000. I was going to change it again at200000. So my question is, what are your experiences with timing belts stripping and is there a way to check the valves without comepletely stripping the engine? I have mine down to the timing belt and some of the intake manifold off.
Old 01-29-2013, 08:00 AM
SamsXE's Avatar
SamsXE SamsXE is offline
Member: #33065
Well. I would say you need to pull the heads to determine if you bent valves or not. THe other way is to throw a new t-belt on there and see...
My Build Thread:
Old 01-29-2013, 08:14 AM
Member: #38848
How do i get those stupid two hoses from the back of the intake. My deconstruction has come to a halt.
Old 01-29-2013, 09:02 AM
intender's Avatar
intender intender is offline
Member: #30982
The larger one on farthest towards the passengers side and the other larger one right next to it are coolant lines. The rest of them on the back of the plenum are vacuum hoses. I think there are two of them on the back. The odds of them coming loose are little to none. I had to cut mine to get them off.
While you are in there doing all that, might as well plan on doing the valve cover gaskets and spark plugs. You will also need a new intake manifold gasket. And if a bad knock sensor is something that concerns you replace it while your tearing it down.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 01-29-2013, 09:08 AM
Member: #38848
I was thinking that too. What kind of plugs do you guys run. I went to get some a while ago and they were 14 dollars each. Also what do you think the chances of me getting out of this with out a valve job are.
Old 01-29-2013, 10:07 AM
muadeeb muadeeb is offline
Banned
Member: #29357
NGK PFR5G-11. Use anything else at your own risk.
50/50.
Old 01-29-2013, 10:52 AM
ShiftingSkys's Avatar
Member: #16608
Your chances are decent. It all depends on how the belt broke/sheared. Worst come to worst you go to LKQ or the junkyard and buy 2 Xterra heads for $100 for both. Or have a valve job/replacement done.
2002 Nissan Xterra
Lifted and Ready to Roll!
  #8
Old 01-29-2013, 12:41 PM
Member: #38848
Do you have any idea the price range for a valve job?
  #9
Old 01-29-2013, 03:07 PM
Member: #38848
I met with a machinist i know and he says hell look at them and it will only be 12 dollars a valve. He also said Nissan's have pretty tough pistons and should not be damaged. Ive pulled the valve covers and all appears fine but then again i dont know what im looking for. Would i be able to see ad valves from the top?
  #10
Old 01-29-2013, 06:33 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Not really unless one was severely bent.
