Can I still drive my Xterra after... - Nissan Xterra Forum: Xterra Forums
Old 01-29-2013, 12:18 AM
redxterra01's Avatar
redxterra01 redxterra01 is offline
Member: #15524
redxterra01 is on a distinguished road
Towing my 2001 4x4 MANUAL across country with all my stuff in a Penske.
When I disconnected the drive shaft and was securing it I accidentally pulled it out and about 1/3 - 1/2 a cup of fluid came out before I got it back in. Two questions:
1. What fluid is this? Transfer case or differential?
2. Can I still drive the Xterra temporarily (to run errands and then get the fluid) or will it be seriously damaged?
Due to time constraints am hoping I can drive the X for a day or two when I get into down, then replace the lost fluid this weekend.
Thanks for your help
2001 Xterra SE
Alpine IDA-305S w/alpine speakers, h/k amp & 12" alpine sub.
265/70/R16 Dynamo ATMs
Old 01-29-2013, 12:29 AM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
You should be OK as long as the DS was secured correctly during towing. How is/was the driveshaft secured during transport?
I assume you unbolted the driveshaft from the diff and then inadvertently pulled the slip joint end out of the transfer case, so T-case fluid.
Old 01-29-2013, 07:03 AM
Member: #15524
Ok great, thank you Kelly.
I used several bungees to hold the driveshaft up (right above the catalytic converter?) and a few more to hold it IN to the driveshaft so it doesn't pop out. Have done 1200 miles so far and it hasn't budged.
2001 Xterra SE
Old 01-29-2013, 06:16 PM
Member: #6445
2000 XE V6 Xterra
Yeah just so long as the slip joint end was in during transport you should be good.
