How to stay past 200k miles - Nissan Xterra Forum: Xterra Forums
Old 01-28-2013, 04:06 PM
PolskiCowboy PolskiCowboy is offline
Member: #38837
PolskiCowboy is on a distinguished road
New member here. Joined site to help make my 2000 Xterra with 241k miles look better. It runs great with only basic repair history (Timing Belt broke at 180k).
Subject Question: What are some good Maintenance repairs to help fuel economy and stay running into 300k (I think it can go 350k). Debating changing the O2 Sensors can cost close to $400 for that.
Thanks!
Old 01-28-2013, 07:35 PM
Itsme's Avatar
Itsme Itsme is offline
Member: #16990
2000 4x4 Xterra
Hi and welcome to Club X
Use only synthetic oils in all areas. Synthetics stop wear, but if you are not using it with that many miles, the first oil change of expensive oil should be done as soon as the oil looks dirty (which is metal and sludge worn off from non-syn oil use). You may even have to do it a couple of times before the normal change times.
By now, I am sure most of the rubber stuff on the engine is hard and needs replacing, including ALL the hoses!
With regular service, it should last a long, long time. (many more years)
Itsme
2000 X SE
Old 01-29-2013, 10:42 AM
Tarditi's Avatar
Tarditi Tarditi is offline
Member: #16959
2006 Xterra
If you're not original owner, make sure there isn't any deferred maintenance - other than that, you've just received some excellent advice in the previous posts.
Welcome to the forum.
Dustin Tarditi
Raleigh, NC
2006 Granite S
