Stock vs. 3"SL - Nissan Xterra Forum
post #1 of 7 Old 01-28-2013, 10:29 AM Thread Starter
kkolze
kkolze is on a distinguished road
Stock vs. 3"SL
Because I am bored and have seen people ask....
Stock:
3" Articulator Suspension Package With Bilstein Shocks
kkolze is offline
post #2 of 7 Old 01-28-2013, 11:11 AM
robcarync
robcarync's Avatar
Quoted: 81 Post(s)
robcarync has a spectacular aura about them robcarync has a spectacular aura about them robcarync has a spectacular aura about them
Garage
That is some flexibility!
2004 Xterra 4X4
33x10.50R15 BFG KM2 | Lokked and Dropped Front Diff | Lift Shackles | 3" UCA's | 3" Bils | 2" BL | TC IAB | Bandit 4x4 Idler Arm Bushings | Grassroots CL | Custom Bumpers and Tire Carrier | Shrock Sliders | RSB Delete | Cobra 19 DX III CB | 4' Firefly
Building my X
How To: < Remove Rear Sway Bar > < PML > < Re-Index Torsion Bars > < Lokk and Drop >
robcarync is online now
post #3 of 7 Old 01-28-2013, 12:37 PM
Revu
Revu's Avatar
2005 Xterra
Definitely cool
Thanks for posting the comparison!
Revu is offline
2005 Xterra
post #4 of 7 Old 01-28-2013, 04:47 PM
OneGearhead
OneGearhead is on a distinguished road
NICE! I was wondering how good the articulator package was. Looks like it flexes out pretty good. What size tires are you running with it? It says you can only run 32's with factory backspaced wheels. Is that true or can you run 33's with some minor trimming?
OneGearhead is offline
post #5 of 7 Old 01-28-2013, 07:28 PM
RacerXXL
Quoted: 85 Post(s)
2000 XE Xterra
Garage
I ran 33x12.50x15 on OEM rims with the articulator lift and a 2" body lift for some time. No cutting required on the rear and only minor plastic trimming required on the front. The rear tire when fully stuffed will either rub on the frame or the inner fender a bit. All I did was to fold over the panel edge of the inner fender to protect the tires from the potentially sharp panel edge.
Currently I'm running 4.75 BS but no pics with that setup but it flexes a bit better now than it did with the OEM rims.
OEM rims and 33's in the pics below and it will go a bit farther now with the 4.75 BS rims.
RacerXXL is offline
2000 XE Xterra
post #6 of 7 Old 01-29-2013, 05:05 AM
OneGearhead
[QUOTE=RacerXXL;524136]I ran 33x12.50x15 on OEM rims with the articulator lift and a 2" body lift for some time. No cutting required on the rear and only minor plastic trimming required on the front. The rear tire when fully stuffed will either rub on the frame or the inner fender a bit. All I did was to fold over the panel edge of the inner fender to protect the tires from the potentially sharp panel edge.
QUOTE]
Good deal!
BTW Racer: your X is awesome!
post #7 of 7 Old 01-29-2013, 02:28 PM
M3C.CA
M3C.CA's Avatar
2003 Xterra
M3C.CA will become famous soon enough
I'll play. Mine's a bit different...
SOA + stock shackles + Eagle stock replacement (no lift) leaf packs:
Full droop:
Rear up-travel will be better after I modify the bumpstops. Right now because there's an additional ~2" of spring perch, leaf pack and spring plate on top of the axle tubes that hits the bumpstops before the tubes would if it was still spring-under. She still stuffs pretty good though...
It's not really an Xterra anymore...
M3C.CA is offline
2003 Xterra
