Capabilities - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > General > FAQ/Common Questions
Old 01-27-2013, 07:28 PM
Gmo48 Gmo48 is offline
Member: #38751
02 Xterra
Gmo48 is on a distinguished road
Capabilities
I got an 02 x and was wondering what the off road specs are. I can't find them anywhere. I wanted to know before I take out on the trails so I don't chew of more then it can handle. And the main one is how deep in water can I go.
My x is stock saving money to start fixing up
Old 01-27-2013, 07:34 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Specs? I don't really understand what specs you are looking for?
As to how deep the water can be look next to your right foot under the center console/dash and you will see the ECU. The ECU goes under water you're going to have problems. The air intake for the engine is basically at the same level as the headlights.
Look around in the trip reports forum and it will give you an idea of what an Xterra is capable of.
Old 01-27-2013, 07:45 PM
Member: #38751
02 Xterra
I meant more like the off road capability of the car like approach angle and departure how deep in water can I go ground clearance that general idea
Old 01-27-2013, 07:58 PM
Member: #6445
2000 XE V6 Xterra
Depends on the spotter and the driver. We have taken stock 1st and 2nd Gens up this trail in Coal Creek.
As far as I know the specs you are looking for do not exist in any Nissan publication, at least not in one I've seen.
What area are you in? Best bet is to look for some fellow Xterra owners to go out and wheel with a couple times. That way you have good spotters and it allows you to see modified trucks and what they do better than your truck. That will give you a good idea on what mods are best for you.
Old 01-27-2013, 08:19 PM
cbxterra cbxterra is offline
Member: #18847
ground clearance is easy. crawl underneath with a tape measure. there's a thread here somewhere someone else wondering about roll over angle. water my guess is as high as the doors you're safe. only problem is when you start into a water hole it's too late to bring out the tape to find how deep it is .
Old 01-27-2013, 09:24 PM
caseycamby's Avatar
caseycamby caseycamby is online now
Member: #16395
caseycamby is on a distinguished road
From Car And Driver...
I'm pretty sure this with a second gen but they said the approach angle is 33.2 and the departure is 29.4 degrees.
I would say the first gen, like yours, would be a little different.. BUT, as to how much.. I really have no clue. I guess this info will give you a pretty good idea. Hope it helps!
2001 Xterra 4x4
Mods:
3" AC AAL SL, Revolver Shackles, LoPro Bumpstops, 2" AC BL, 33x12.5 Duratracs, 15x8 Pro Comp 52 Rock Crawler wheels, Rage roof rack, Cherry Bomb Extreme dual exhaust, Undercoated, Pioneer DEH-3200UB deck, Sony Xplod door speakers, 2 12" Kicker Comps in Kicker box, 350W Bolt amp, Cobra 75 WX ST CB & Firestick FS4-W Antenea, SRB Off Road Lights, lots of paint and many mods to come...
XTERROR POWER!!
"My Official Build Thread"
Old 01-27-2013, 09:54 PM
ryandavenport's Avatar
ryandavenport ryandavenport is offline
Professional
Member: #15330
2007 Xterra
ryandavenport has a spectacular aura about themryandavenport has a spectacular aura about themryandavenport has a spectacular aura about them
Stats really don't matter once you get on the trail. Numbers won't do much for you when you don't know what to do with them. Water is difficult to judge a depth on, so try to avoid it. If you can't avoid it, test it with a stick to find the depth and check the bottom. If the bottom is solid, you are safer to go deeper. Also, look at the surrounding terrain. Is there a waterline on trees around it? How steep are the banks? You can bet they keep the same angle underwater.
How tall is the rock? Put a tire over it instead of straddling it. When you come off the rock steer away from it so as not to hit the side of the truck on it. You really shouldn't be doing stuff that difficult without protection though. My armor has already paid for itself multiple times over on the trails. Sometimes there is no way around coming down on skid plates and sliders. The crash sounds better than the crunch.
2007 Xterra S 4x4
Wheels, Tires, and Suspension
285-75 R16 BFG AT-KO, Pro-4X Wheels, 2" OME Lift
NXRocks Skids, TAG Rear Bumper, White-Knuckle Off-Road Rock Sliders
Exterior
Xoskel Bumper Mount Bracket, Blacked out Emblems, Weathertech Vent Visors, FOURTREKS Hi-Lift Mount, Wilson1000 CB Antenna
Pioneer AVHP3200DVD, Midland CB, Compass Mirror, Nissan All-Weather Floor Mats, Nissan Carpeted Cargo Mat
  #8
Old 01-27-2013, 10:00 PM
caseycamby's Avatar
Member: #16395
All very true. Well done, sir.
2001 Xterra 4x4
Mods:
XTERROR POWER!!
  #9
Old 01-27-2013, 11:09 PM
Member: #38751
02 Xterra
Thanks guys I will take all ur guys advice and go little by little and find my self s good spotter n avoid water at all cost unless I have to go through it thanks for the tips guys.
Probably going to buy skid plates first I like my car in one piece not multiple rather spend a couple hundred versus couple thousand on a fix that could of been avoided
  #10
Old 01-27-2013, 11:38 PM
caseycamby's Avatar
Member: #16395
Sounds like a plan, Stan! Good luck with it!
2001 Xterra 4x4
Mods:
XTERROR POWER!!
Tags
capabilities, off road
