Aluminum radiator vs Plastic??? HELP!!! - Nissan Xterra Forum: Xterra Forums
Old 01-27-2013, 11:32 AM
Alex Montayre Alex Montayre is offline
Member: #38252
Alex Montayre is on a distinguished road
Im in need of ordering a new radiator because my plastic one is cracked up top and I wanna know the pros vs cons of having an aluminum radiator??? anyone with experience or if you have one please respond lol. i know its more expensive but i believe its worth the price. btw i have a 2000 xterra.
Old 01-27-2013, 01:06 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
No experience with the all metal ones but certainly they will be less prone to cracking the tanks then a plastic tank model. If you have to replace the radiator I suggest installing one from a 2002 S/C model as it has a thicker core and will increase the cooling capacity/efficiency of the system.
2000 radiator on the left and the 2002 S/C radiator on the right. It is a direct swap no fabrication needed to get it to fit.
Old 01-27-2013, 02:05 PM
Tarditi's Avatar
Tarditi Tarditi is offline
Member: #16959
2006 Xterra
Only downside I'm aware of for aluminum (or "ah-loo-min-ee-um" if you're not from around here...) is expense...
Dustin Tarditi
Raleigh, NC
2006 Granite S
Old 01-27-2013, 06:05 PM
k-man's Avatar
k-man k-man is offline
pics or it didnt happen
Member: #7113
2001 1stG Xterra
k-man is on a distinguished road
CSF makes an all metal one, but there copper and have a tendency to crack near the lower mounts. I went thru 2 before going back to the plastic cap style. And definitely go with the 2 core SC model.
"This aint gonna be no cake walk in the tea park"
([ ][--o--][ ])
Old 01-28-2013, 10:17 AM
Itsme's Avatar
Itsme Itsme is offline
Member: #16990
2000 4x4 Xterra
I am a firm believer in all metal radiators.
When I was a hard core off roader, there were several times I need to piece together a damaged radiator.
You can't do much with a plastic thing in a hundred pieces! On the other hand a small torch, solder and flux can get you home, when confronted with such damage.
I know others will tell you they never had a radiator issue and they are fine with plastic radiator tanks, but I am not one of them!
I have owned two first gens and each time, they got new all metals in them! (before the the problems cropped up)
When I go offroad (and I am no longer hard core) I carry an offroad tool kit that includes torch, solder and flux.
There are many things you should pack with you on an offroad outing.
be safe, not stupid when going into the bush. A failed offroader rig , could find themselves in a life or death situation. I have tried to always go with another rig, but even that can not prepare you for survival, if you need it.
There are posts here on offroad kits. A good supply of drinking water is very important!
Itsme
2000 X SE
