tps?? help - Nissan Xterra Forum
post #1 of 4 Old 01-23-2013, 04:12 PM Thread Starter
trey_567
trey_567 is on a distinguished road
tps?? help
Here we go..i recently reinstalled my timing belt after my cousin put it on wrong.It ran bad for two days and wouldnt crank anymore, so i tore everything back down and found the belt wasnt align right. i found all marks at tdc an reinstalled the belt...it started right up after that..but here is my problem. When i crank it idles high sometimes..also when im driving i get the herky jerky effect when i press the gas sometimes it goes away. It dosent shift out of second gear but it has plenty power. i was wondering was it still the timing belt or something else like the tps? All help is greatly appreciated. Thanks in advance guys.
trey_567 is offline
post #2 of 4 Old 01-23-2013, 05:09 PM
Chef
Seasoned
Chef's Avatar
2003 Xterra
Chef is on a distinguished road
Did you loose any trans fluid? Check that out
Chef is offline
2003 Xterra
post #3 of 4 Old 01-23-2013, 05:26 PM
intender
intender's Avatar
Quoted: 1 Post(s)
2000 SE Xterra
Garage
tps can cause issues similar to yours. did you remove it? If so try adjusting it.
<<<-click for build
intender is offline
2000 SE Xterra
post #4 of 4 Old 01-24-2013, 06:25 PM Thread Starter
trey_567
To chef i did loose some trans fluid but i replaced it. I also tried adjusting the tps.
trey_567 is offline
