! Help car wont start!! - Nissan Xterra Forum: Xterra Forums
Old 01-23-2013, 12:52 PM
sfyessey sfyessey is offline
Member: #35069
sfyessey is on a distinguished road
I have a 2000 Xterra 3.3L V6 I got in July. I replaced the starter in September. Got in her today to go to work and NOTHING happened! Tried to jump her...still nothing. I don't think it's the battery or alternator since everything electrical worked and trying to jump her nothing happened. No starter ticking sound. Is this a common problem???? Another unrelated question. ABS light keeps coming on but I have no idea how to pull codes. Tried what the manual says to read them but no ABS light flashing when grounding terminal 8. Every now and then when I brake the wheels kind of freeze for a second. Any insight?
THANK YOU IN ADVANCE!
Old 01-24-2013, 02:24 PM
robotapartments robotapartments is offline
Member: #27966
robotapartments is on a distinguished road
i have the same car same year, my ABS has been out pretty much since i bought it, i just adjusted my driving knowing i don't have ABS, some people who are better drivers than me prefer no ABS so they can in complete control. Over the years I have not had a problem with not having ABS, i just kinda sucked it up and will have it fixed one dayn when i can afford it.
as for the car not starting, check the cables, connections, fuses and the dont forget the fuse box on the positive side of the battery, could be a loose connection.
if you can get it cranked the trick to test battery vs alternator is to have the car running preferably with a fully warmed up engine, then disconnect the battery. if the car turns off, you have an alternator problem, if not, then you most likely have a battery issue.
no ticking usually means the battery is dead as a doornail.
the brakes freezing im guessing is the brakes locking because you don't have ABS anymore
Old 01-24-2013, 02:29 PM
Member: #27966
you can go to autozone or your store of preference and they should be able to check for any codes if you ask them to check it out
all they have to do is plug a little doodad into the car and check
***MOD move to Won't Start Forum***
Old 01-28-2013, 08:45 PM
mttor03 mttor03 is offline
Member: #38847
03 Xterra
mttor03 is on a distinguished road
mine did this after 2 batteries from repair shops found the ignition relay under dash bad
