Parked Rollover Rating? - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > General > FAQ/Common Questions
Old 01-22-2013, 04:31 PM
dmski's Avatar
dmski dmski is offline
Member: #37695
dmski is on a distinguished road
I got to around 30 degrees the other day and that was enough to make me pay some serious attention (for those veterans I'm sure your comfortable sitting on the passenger but for us noobs it was sure fun!). I've tried to look it up but it doesn't seem to be a hot topic so its why I ask. I'm curious how far a first gen xterra parked can safely lean before rolling? Lets assume its has no gear in it or on the roof and it is the 4WD model. Anyone have a link to this or know a factory spec?
Thanks!
2000 Xterra XE 5-spd
  • [X] Light Bar with 4 Hella Lights
  • [X] CB/Firestick Install
  • [ ] Relocate Rear Axle Breather
  • [ ] Lobo Rack
  • [ ] Seafoam
  • [X] Mudflap/sidesteps delete
  • [X] Window Vinyl
  • [X] Front Tow Hook Replace
  • [ ] Tow Hitch Install
  • [ ] Rock Sliders
  • [ ] PML
Old 01-22-2013, 11:13 PM
robcarync's Avatar
Member: #33023
Always been curious of this too...
2004 Xterra 4X4
To Do
Building my X
Old 01-23-2013, 06:58 AM
Dbrown016's Avatar
Dbrown016 Dbrown016 is offline
Member: #28382
Dbrown016 is on a distinguished road
What about the rolling rollover rating? On my X, without the sway bars, my X feels like its going to roll just making a U-turn! haha
2002 2wd SE
2 Alpine E10s,
1500W Alpine amp
700w kicker amp
7" Android Tablet in Dash
Cobra PA/CB system
Rims painted black
32" Hankook Dynapro ATM's
Hella 500s
Painted top rail roof rack
Torisons cranked
10000k HID Kit
Homebrew Mountain Bike Roof Mount
Old 01-23-2013, 11:24 AM
midget28's Avatar
midget28 midget28 is offline
Member: #4620
midget28 will become famous soon enough
This is the 2nd farthest I have ever been offcamber and I had to climb out the window. The only time it leaned over farther was a real pucker factor.
SAS no sway bars and 37s.
02 Xterra beaten and battered but still going strong. MAKE IT OR BREAK IT. http://www.miobi.org
3/4ton SAS on 37s.
Build thread http://www.clubxterra.org/forums/sho...ight=midgets+x
Old 01-23-2013, 01:22 PM
Drew7997 Drew7997 is offline
Seasoned
Member: #28003
2001 XE V6 Xterra
Drew7997 is on a distinguished road
I think it all depends on if there is a lift, if so how high. As that raises your center of gravity.
If your center of gravity is on the + side of the lean, you would continue rolling. I assume you knew that though-
My X
Old 01-23-2013, 01:44 PM
robcarync's Avatar
Member: #33023
I'll draw a free body diagram and make a physics problem out of it later
2004 Xterra 4X4
To Do
Building my X
Old 01-23-2013, 05:12 PM
ShiftingSkys's Avatar
Member: #16608
Sounds like some banging going on O.O It would take a good amount of force at stand still or a very good angle. ANything you could possibly do from in the cabin most likely will not tip it.
2002 Nissan Xterra
Lifted and Ready to Roll!
  #8
Old 01-23-2013, 05:50 PM
dmski's Avatar
Member: #37695
Wow some serious angle there midget28! nice x as well! I'm talking a bone stock or just a pml lifted x for simplicity sake. once it gets lifted passed that you just have to be wary. But is there a true angle measured by nissan for the max parked rollover rate. Don't want to check it myself haha!
At speed it doesn't matter since you can roll a car at any speed really.
  • [ ] Lobo Rack
  • [ ] Seafoam
  • [X] Window Vinyl
  • [ ] Rock Sliders
  • [ ] PML
  #9
Old 01-23-2013, 07:10 PM
midget28's Avatar
Member: #4620
Theres just to many variables to put a standard number on it.
Things like :
tire size
tire pressure
tire ply
suspension strength (springs wear out over time)
shocks (same as above)
ground softness
vehicle weight (even between the same make and model theres going to be differences)
wind speed
And theres lots more I dont feel like typing.
3/4ton SAS on 37s.
  #10
Old 01-23-2013, 07:35 PM
robcarync's Avatar
Member: #33023
How many passengers are in the car...how much they ate for lunch, etc
2004 Xterra 4X4
To Do
Building my X
