P0505 After Timing Belt and Valve Job - Nissan Xterra Forum: Xterra Forums
Old 01-22-2013, 08:20 AM
b11dragone b11dragone is offline
Member: #38686
2003 Xterra
b11dragone is on a distinguished road
Exclamation P0505 After Timing Belt and Valve Job
Hey guys, I was hoping you could help me out. Awhile back I did he knock sensor relocate to pass emissions, and this worked fine. Well my timing belt went early on me (although I should have replaced it) and I needed a timing belt and valve job. I did the water pump, head gasket etc. while doing the other work. So I get my Xterra back from the shop and it now has two P0505 codes. So I am assuming its an issue with the IAC. My question is this, it looks like my mechanic did not plug in the harness that I tapped into for the knock sensor relocate, but is the harness for the IAC also in that group? I spliced into the harness where it first splits on top of the engine bay and I could have sworn there was another group of wires in there that I did not touch. Any help would be greatly appreciated. Thanks
Old 01-23-2013, 09:28 AM
Itsme's Avatar
Itsme Itsme is offline
Member: #16990
2000 4x4 Xterra
Go to the DIY section and look at the pics. It may identify the wires more clearly.
Itsme
2000 X SE
Old 01-23-2013, 11:28 AM
muadeeb muadeeb is offline
Banned
Member: #29357
Yes, the IACV is located on the same 8-pin connector as the Knock Sensor; the black one on the right.
