Head gasket help - Nissan Xterra Forum: Xterra Forums
Old 01-16-2013, 01:50 PM
Gotlift04 Gotlift04 is offline
Member: #38582
Gotlift04 is on a distinguished road
Head gasket help
Only the right head is leaking. Can I just replace this side without taking. The intake manifold off. I'm strapped hard on cash. I've done heads before so I know I can do it just need to fix it and get it back on the road ASAP. Thanks
Old 01-16-2013, 06:49 PM
Xterra Mike's Avatar
Xterra Mike Xterra Mike is offline
Silver Submarine
Member: #2784
2001 SE Xterra
Xterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the roughXterra Mike is a jewel in the rough
No. The upper and lower intake manifold has to come out first. The lower intake manifold bolts to the heads. Sorry bud.
2001 XterraSE
I Love Mud
I am XTERRA MIKE!
Build Thread:
http://www.clubxterra.org/forums/sho...terra+mike%27s
Fan Club:
http://www.facebook.com/group.php?gid=118570174822483
Old 01-16-2013, 06:58 PM
Member: #38582
Thanks. I'm still not sure if its the head gasket though. I'm loosing antifreeze when it's running from the right side. I have it off now and with the pressure tester on and it's not really loosing any pressure. I found I'm leaking oil from the valve covers. Any idea on the antifreeze issue?
Old 01-16-2013, 06:59 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Passenger side? Towards the back, on the side, near the front?
Old 01-16-2013, 07:00 PM
Member: #38582
Right side towards the rear of the motor. Behind the heat shield and above the starter
Old 01-16-2013, 07:15 PM
Member: #6445
2000 XE V6 Xterra
Could be off of one of the small lines on the back of the intake. Are you sure it's not coming off the firewall from the heater core? They are notorious for cracking.
Old 01-16-2013, 08:31 PM
Member: #38582
After looking into it more I noticed very small drips coming of the exhaust manifold bolts. Still not sure where it's coming from
  #8
Old 01-17-2013, 10:22 AM
outwiththeold's Avatar
outwiththeold outwiththeold is offline
Member: #4028
00 Xe 4x4 Xterra
I did mine ps and ds(head gaskets) on my 2000.where do you live in Il?
warn manual hubs,PML, and a ditched rear sway bar.K&N Drop w/ resonators removed.Plastics Repainted Black.
  #9
Old 01-17-2013, 10:35 AM
Member: #38582
I'm about 40 miles west of Chicago
  #10
Old 01-17-2013, 10:44 AM
Member: #4028
00 Xe 4x4 Xterra
Well, carol stream is 32 miles west of chicago. need some help, let me know.
