Hello guys, im just new on the site and I know this is a noob question, but please help me out. I'm planning to replace my 2003 xterra oem filter with a brand new k&n drop in air filter, my question is, am i going to have a problem with my MAF sensor once i installed the brand new filter? Thanks in advance
__________________ 2004 Silver XE V-6 4x2
Inside: Pioneer 3-way door speakers, Aux input above factory unit, Kicker 12" sub, Kicker 250 amp
Outside:PML, 2" BL, Calmini IAB, rear Bilstein 5100's, 265/75/16 Falken Rocky Mountain A/T tires, Bedlinered plastics, Plastidipped emblems, OEM add on fog lights, Cherry Bomb glasspacks
Under the Hood: Stock air intake mod w/ K&N drop in, Amsoil oil and filter, and differential fluid, new timing belt, water pump, thermostat, radiator, belts and hoses.
The only times you have to worry about the MAF is if something gets it dirty (This can happen when using an oiled filter that has too much oil on it, or running a bad filter that is letting too many particles through which then stick to the sensor) or when upgrading to a larger intake tube diameter. It doesn't make much sense to install a 4" intake pipe when all the air still has to make it through a 3" MAF is all that means.
A drop in filter won't affect it, and K&N makes really good products.
Thanks for the input guys, i know i can get help from a lot of pros here. Now im going to search where i can get the best price for the k&n for my x! Thanks!
Do what I have always done. I have always used K&N's. I clean and oil the filter and vacuum the living hell out of it with a really powerful shopvac or a vac from a self serve carwashto suck out any of the excess oil used to re-charge the filter.
Just a follow up question guys, since i'm planning to put a k&n drop in on my 2003 X, do i need to disconnect my battery before installing it? i've searched a lot on this (googled it and shows different threads from different forums) and its got mixed opinions. They say that i need to disconnect the battery for a certain number of 1+hours, turn the lights on for 10-15 minutes or until its fully drain, in order for the computer to be reset so that the computer will recognized any modifications, And some say it is not necessary to disconnect the battery, just replace it and done (maybe 15 minutes of time)
I just want to know what my fellow members did to their X and what are their experience after doing it (ie. problems if not disconnecting)
I just swapped mine in....no battery stuff to deal with. They are referring to the ECU computer thingy "remembering" old fuel maps blah blah blah...I don't see any reason to deal with that...swap it in like you would a normal air filter
Start the truck, disconnect the MAF, truck dies, turn off ignition, re-connect MAF, start truck, done. What's to deal with? It takes less then a minute to complete the whole process of clearing stored values.
