Rough idle and Service Engine Soon light - Nissan Xterra Forum: Xterra Forums
Old 01-14-2013, 07:02 AM
arretX00 arretX00 is offline
Member: #24164
arretX00 is on a distinguished road
I noticed a rough idle when leaving the house the other day and decided to turn around. Before i could get home my service engine soon light came on so i hit the local auto parts and had it scanned. It said knock sensor and misfire in no. 2. Is the misfire related to the knock being bad or is this a seperate issue?? Just want to make sure so i can remedy the problem asap. Thanks in advance for any help.
Old 01-14-2013, 08:17 AM
smk379's Avatar
smk379 smk379 is offline
Member: #38330
2003 Xterra
smk379 is on a distinguished road
Don't worry about the knock sensor code, that's not why the SES light is on. The misfire code and rough idle probably has something to do with your distributor-wires-or plugs.
Old 01-14-2013, 10:28 AM
Member: #24164
Thats kinda what i have gathered from some other posts. Im guessing that the knock code might have just been in the history and the mis fire is what kicked it. Guess i will start with plugs and wires, it hasnt had new ones so its over due. Any advice on the plug by the firewall??? And is the distributor a pain if i need to do that?? Thanks again for your help
Old 01-14-2013, 11:27 AM
ayjay ayjay is offline
Seasoned
Member: #32963
ayjay is on a distinguished road
I had this exact thing happend. I replace the cap and rotor, and replaced the plugs and wires...well, some of them. I'm still trying to figure out how the hell I'm going to reach #6...
2000 XE V6 4X4 5speed, AC PML, RS5000s, K&N drop-in, AC Idler brace, Yakima kayak rack, Shrockworks Skids, custom sliders.
Old 01-14-2013, 11:55 AM
kms1990's Avatar
kms1990 kms1990 is offline
Member: #34507
get a stool len over ngine (lay on it and you can get to it
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
Old 01-14-2013, 02:13 PM
smk379's Avatar
Member: #38330
2003 Xterra
The distributor is easy to replace but it costs around $250. Just had to replace mine a couple days ago. Your best bet would be to just replace the distributor cap and rotor first, which will be about $30 and very easy to do.
I was just reading about that number 6 plug, I think the best way is plug socket>6" extension>universal joint>12" extension>ratchet. Once its almost fully unthreaded use an old plug wire boot to pull it out and also to put the new one in.
Wish I wouldve found all that out myself beforehand, I had to take it to a mechanic a pay a half hour labor to get the damn thing lol.
Old 01-22-2013, 12:56 PM
vosot2003 vosot2003 is offline
Member: #37897
vosot2003 is on a distinguished road
To get the one in the back get a stool lay on the plenum put the socket with a six in extension then attache the universal joint then a ten inch extension to undo. Careful not to drop it.
  #8
Old 01-22-2013, 06:44 PM
cbxterra cbxterra is offline
Member: #18847
agree with using two extensions and a u joint. do it 2-3 times and you'll get used to it. [still a pain though].
