Roof Rack, Hi-Lift Jack Support - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Nissan Xterra Mods > Exterior Mods
Old 01-13-2013, 10:37 PM
scott-bc's Avatar
scott-bc scott-bc is offline
Seasoned
Member: #22558
scott-bc is on a distinguished road
I wanted a place to mount my jack and I have seen other ideas on this forum so I decided to do a variation from that. I bought a couple of 6"-7" long 1/2" bolts, 6 washers, 2 nuts/lock washers, 3" long SS pipe(slide over the big bolt, acts as a spacer) and some easy to turn black plastic knobs with the nut built inside. First get an idea of where you want your jack, then drill a hole through the 2" aluminum rack tube. Place the bolt and washer through the back side, slide on washer, small piece of pipe, washer, lock washer and then nut. Make sure this is very tight. Next place jack on the first mount, then mark where you want the next bolt to be. Ideal to have one in the front and also in the back. Repeat process again. Place your new bolt mounts through the jack holes and then screw on black knobs. For safety reasons I would lock up the jack.
[X] Painted plastics [X] Remove step rails
[X] PML [X] 31" Mud tires
[X] Remove mudflaps [X] Custom Front Bumper
[X] Rear Sway Bar Gone [X] Roof Rack
[X] Jack/shovel roof clamp[X] Rear Tire Carrier
[X] Rear Tire Carrier [X] Shovel and Hi-Lift Mnt
[ ] Winch [X] OBA
[X] CB Radio [x] Skid plates
[ ] 2in Body Lift& SAS
[ ] Retired from work and go 4x4'ing
Old 01-14-2013, 12:37 PM
Revu's Avatar
Revu Revu is offline
Member: #27745
2005 Xterra
That is a really cool idea, using the stock rack to support the jack.
Definitely loads cheaper than buying a whole aftermarket roof rack. Just lock that thing up so no one comes by and takes it and you should be golden!
The Project Goes On...
Old 01-14-2013, 01:31 PM
thanks28's Avatar
thanks28 thanks28 is offline
Member: #22923
thanks28 is on a distinguished road
Sort of the same thing I did except a version for the basket.
"Only the Best"
2002 Xterra SE 4x4 Solar Yellow
  • Cherry Bomb Glasspack Muffler
  • Concept Customs Lightbar w/ Pro Comp Long Ranges
  • Tinted All Windows to Match
  • Full Kenwood audio from Deck to Subs
  • Front Off Road Lights
  • PML
  • Custom Built Rock Sliders w/ Bedliner
  • Roof Basket w/ Spare Tire
  • DIY Hi-Lift Mount
  • 18" Rockstar XD wheels with 33"x12.50 Toyo Open Country Tires
Big Bird Build
Old 01-14-2013, 02:48 PM
intender's Avatar
intender intender is offline
Member: #30982
You should get a lock on that thing, people will steal them in a heartbeat.
Otherwise, looks good.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 01-14-2013, 03:36 PM
thanks28's Avatar
Member: #22923
Mine does have a lock through the rear bolt. As for the one posted for this thread he could add one the same way.
"Only the Best"
  • PML
  • DIY Hi-Lift Mount
Big Bird Build
Old 01-14-2013, 11:03 PM
scott-bc's Avatar
Seasoned
Member: #22558
I have only had it on the roof when I go on a 4x4 trip but was thinking today how will I replace my flat tire without it. The stock sicsor jack probably won't help after the PML and larger tires added. I do plan on adding a lock. If I keep it on the roof all the time I have a feeling its going to rust out badly being exposed to the wet winters up here.
[ ] Winch [X] OBA
Old 01-15-2013, 08:48 AM
intender's Avatar
Member: #30982
I had a piece of 4x4 wood about 10 inches long in my truck until I got my hi lift. I used a chisel to carve out a piece the same size as the top of the jack about 1/2" deep so it would sit on the top of the jack and not fall off constantly. But the hi lift is already there so you might as well carry with you.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
