Square to Round Lights?? - Nissan Xterra Forum: Xterra Forums
Go Back   Nissan Xterra Forum: Xterra Forums > Tech Talk > Modification Questions
Old 01-13-2013, 06:51 PM
scott-bc's Avatar
scott-bc scott-bc is offline
Seasoned
Member: #22558
scott-bc is on a distinguished road
Has anyone found aftermarket lights that will take a 1st gen square and make them round? I was thinking of taping off a circle in the center of the glass and paint everything else black. You think that would greatly reduce the amount of light? Good or bad idea? Right now they don't put much light out as they are. I know some people completely tint the entire glass.
[X] Painted plastics [X] Remove step rails
[X] PML [X] 31" Mud tires
[X] Remove mudflaps [X] Custom Front Bumper
[X] Rear Sway Bar Gone [X] Roof Rack
[X] Jack/shovel roof clamp[X] Rear Tire Carrier
[X] Rear Tire Carrier [X] Shovel and Hi-Lift Mnt
[ ] Winch [X] OBA
[X] CB Radio [x] Skid plates
[ ] 2in Body Lift& SAS
[ ] Retired from work and go 4x4'ing
Old 01-13-2013, 07:20 PM
intender's Avatar
intender intender is offline
Member: #30982
I did that once in my younger (and much more.....inexperienced) days. I would vote against it. The paint would flake off of the plastic very easily, and it ended up looking like crap after about a month when running at night. Light would leak through all the little nicks and dings. repainting them was a pain, so I gave up at some point and decided to sand it off, but the paint had soaked into the plastic by that point and no amount of sanding was bringing it out. It just ended up looking like I had really really dirty foggy lights in the end. I also ended up having to put 2 sets of fog lights on the car Just to drive around and see, because when they were painted I couldnt see crap at night.
<<<-click for build
Lifted it
cut a bit
Lifted it more
welded a lot
33's mt's
cut some more
Got a winch
Old 01-13-2013, 08:12 PM
birddog01 birddog01 is offline
Member: #34772
birddog01 is on a distinguished road
I didn't go round but I did paint angry "brows" on the top of the lights to make it look a bit more childish, er sorry, make it look more "aggressive". Yeah, that's the ticket!
I wouldn't do round because you'd wind up with two 4" circles. With a nose full of rectangles on the v1.0 Xterras the round lights would look out of place.
As far as light output goes, try re-aiming them a bit. That made a big difference on mine.
Ever meet someone that accidentally bought a set of 35s?
They call me Birddog. Master of the Sawzall.
01 XE/SE
5 speed
Currently
PML
35x12.50x15 BFG A/T on Legos
De-Plastified and Blacked out
Old 01-13-2013, 08:27 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Square lights can be made round by retrofitting a 1.5 front end. Sort of round can be done as well by retrofitting HID projectors into the OEM square housings. I have a set on my truck as do a few others.
Old 01-13-2013, 10:40 PM
scott-bc's Avatar
Seasoned
Member: #22558
Thats a great idea, I will have to try that. Right now the lights I have just suck! Even new bulbs. I could also try the new bulbs that put out more light.
[ ] Winch [X] OBA
Old 01-14-2013, 06:50 AM
iwashmycar's Avatar
iwashmycar iwashmycar is online now
Member: #31171
2003 Xterra
iwashmycar is on a distinguished road
The square lights look 100X better than the rounds!! I'd be happy with them. If it didnt require a new hood, I'd swap out for the old square lights if I could lol
I do have Silverstar zXe bulbs in my FJ and they are BRIGHT. I would recommend them.
-Adam
2003 Nissan Xterra XE 2WD AT
2007 (O|TOYOTA|O) FJ Cruiser 4WD AT
