new member post - Nissan Xterra Forum: Xterra Forums
Old 01-13-2013, 12:31 PM
vinny chase vinny chase is offline
Member: #38512
vinny chase is on a distinguished road
new member post
Hey,
I was interested in seeing what this site is about since i purchased an xterra early last year and was interested in getting some info on certain upgrades i am looking to do on my truck. lift kit, suspension, tires and so on.
thanks
Old 01-13-2013, 01:35 PM
02 SE SC 4X4 02 SE SC 4X4 is offline
Member: #16113
02 SE SC 4X4 is on a distinguished road
Welcome to clubX Vinny. There a lot of info for you. Use the search feature. Use key phrases such as "poor man's lift" "pml", "uca", "body lift". As for tires, many like the Goodyear Duratrac and the BF Goodrich All-terrains. Have fun with your X.
Old 01-13-2013, 01:54 PM
Ehlectric's Avatar
Ehlectric Ehlectric is offline
Member: #36577
Ehlectric is on a distinguished road
Welcome Where are you from in Canada? There's alot more specific clubs for your area if you'd like to do some off roading as well.
'02 Xterra Supercharged 4WD
My plans:
Paint plastics to black [1/2]
Fog Lights (fixed) [X]
PML or bigger lift [ ]
Air Intake Mod [ ]
Brakes [X]
CB radio [ ]
Breather Tube [ ]
Old 01-13-2013, 02:18 PM
Member: #38512
thanks for the info. i need to redo my back suspension so thats where i got the idea to lift er up a bit. im not looking to lift to much just about 1 1/2 inchs. When i change the suspension any idea if i could just get extended suspension without the lift kit?
Old 01-13-2013, 02:22 PM
Ehlectric's Avatar
Member: #36577
Look into the PML (Poor man's lift) I'm in the process of buying shackles for mine. It seems like a relatively easy thing to do. You should get the extended suspension just incase you do put a lift, then you won't be down money. https://www.4x4parts.com/nissan/xter...ck-p-1925.html Those are a good example. They're cheap but also good quality. You can buy better of course, but it really depends on the kind of off road you'd be doing.
My plans:
Air Intake Mod [ ]
Brakes [X]
CB radio [ ]
Breather Tube [ ]
Old 01-13-2013, 03:53 PM
Member: #38512
thats a good idea but wouldnt i need the lift kit if i put in 3 inch extended rods in?
im in NB sorr forgot to answer your question. trails are wicked around here.
Old 01-13-2013, 06:20 PM
cbxterra cbxterra is offline
Member: #18847
if you've got to replace the springs do that first. reason I say is I had broken main leafs [both sides] and had them replaced. the place that did it said it'd settle down in time. that was about 4 months ago. it's still up a couple of inches. now I've got to figure out how to loosen the rust on the torsion rods and do the front of a poor man's lift.[she's nose down a bit] the back was "free". don't forget when yopu go up you'll need an alignment- the specs are here somewhere.
  #8
Old 01-14-2013, 08:53 AM
Itsme's Avatar
Itsme Itsme is offline
Member: #16990
2000 4x4 Xterra
Hi and welcome to Club X.
Itsme
2000 X SE
