maf sensor - Nissan Xterra Forum: Xterra Forums
Old 01-09-2013, 05:23 PM
hankwood hankwood is offline
Member: #264
hankwood is on a distinguished road
maf sensor
2000 xterra 3.3 runs and idles rough, the distributor has been changed and it ran fine for six months. I have kept up with all maintenance so far and about a month ago the X started to sputter and idle rough once the motor was warmed up. I have replaced the fuel sending unit and the fuel filter. After reading everything I can find that could be the problem I cleaned the Maf sensor and It did not help. I just disconnected the Maf and the rough idle went away but at 2500 rmps the engine would sputter so I think I found the problem. The X has 125,000 miles. I replaced the dist. due to the bearing being shot. What do you think should I just replace it and where is the best place to get one. Thanks
Old 01-09-2013, 05:48 PM
TJTJ's Avatar
TJTJ TJTJ is offline
Member: #374
TJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to beholdTJTJ is a splendid one to behold
Talking
The intake runner from the air box to the intake plenum can get a crack on the underside...which leaks air under some conditions and not others due to flex and vibration....check it for leaks/see if its pressure tight.
-TJ
Old 01-09-2013, 07:15 PM
Member: #264
The rubber boot is tight and has no cracks?
Old 01-10-2013, 10:38 AM
Itsme's Avatar
Itsme Itsme is offline
Member: #16990
2000 4x4 Xterra
Have you checked all the things that attach to the intake hose and if they are also tight? Any leaking in the air intake system after the maf, will cause rough idle.
You may also have sticky/dirty/messed up injector.
Any codes?
Itsme
2000 X SE
Old 01-10-2013, 03:33 PM
Member: #264
Should have explained a little better, the rough idle would eventually drop and kill the engine. While driving and the engine would get to operating temp the engine would stall and die at any rpm. I took the MAF back out and cleaned it and noticed the tiny wire between the two posts is loose? The rough idle is still gone with the maf disconnected.
Old 01-13-2013, 08:55 PM
kms1990's Avatar
kms1990 kms1990 is offline
Member: #34507
thats a sure fire shot, its the maf sensor especially since you said the wire is loose and when you unplug it rough idle stops.
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
Old 02-06-2013, 02:35 PM
Member: #264
MAF sensor replaced and codes po100 and po325 cleared. The x ran fine today in the city and on the highway. Thanks for the help....
