throwout bearing - Nissan Xterra Forum: Xterra Forums
Old 01-07-2013, 10:08 PM
alfredogarcia7356 alfredogarcia7356 is offline
Member: #38404
2003 Xterra
alfredogarcia7356 is on a distinguished road
throwout bearing
I have replaced the bearing with aftermarket how come my new bearing acts like a old one by squealing when realeased or slowing down while in gear
Old 01-07-2013, 10:41 PM
Member: #38404
2003 Xterra
does the new bearing have to be set up for contact with the pressure plate to stop the noise
Old 01-07-2013, 11:02 PM
Creepy Cruiser's Avatar
Creepy Cruiser Creepy Cruiser is online now
I'm kinda wacko
Member: #1873
06 Zterra Xterra
Creepy Cruiser is a splendid one to beholdCreepy Cruiser is a splendid one to beholdCreepy Cruiser is a splendid one to beholdCreepy Cruiser is a splendid one to beholdCreepy Cruiser is a splendid one to beholdCreepy Cruiser is a splendid one to beholdCreepy Cruiser is a splendid one to behold
Welcome to the club.
When it's just idling, (but not moving), is it loader or quieter with the clutch pressed down to the floor?
Old 01-08-2013, 08:52 AM
Itsme's Avatar
Itsme Itsme is offline
Member: #16990
2000 4x4 Xterra
When you replaced the throw out bearing, did you also replace the bearing in the flywheel? This could be the squealing you are hearing.
It should always be replaced, whenever the transmission is removed.
Itsme
2000 X SE
