Rough idle problem - Nissan Xterra Forum: Xterra Forums
Old 01-07-2013, 07:48 PM
proudxterraowner's Avatar
proudxterraowner proudxterraowner is offline
Member: #33663
2003 XE V6 Xterra
proudxterraowner is on a distinguished road
Rough idle problem
This may or may have been talked about and when I searched there was a bunch over it but they don't have the same symptoms. About 4 days ago, I went muddin and after, I went to the car wash and sprayed most the mud off and I opened the hood to kind of get some of the mud out of the engine compartment and I didn't spray to hard but after finishing up, I got in and started and instantly it was idling crappy. My thought was that I could have gotten something wet and I will just leave it at my grandparents for maybe two days. I went and got her Sunday evening and cranked her up and it will idle then drop some it feels like its going to die but the rpms are well above 500. In drive and reverse it does it a lot. I know that the spark plugs probably haven't been changed cause for the this year and a half I've had it going from 88k miles to 119k now, I've haven't done em. Could that be it? Or a coil or something? Kinda puzzled.
I'm Hunter!
03 XE 4X2
(X) Remove damage multiplier(grille guard), steps, n mudflaps
(X) K/N drop in
( ) bull bar
( ) better set of allterrains
You want to race me in a car? Sure! Let's get off the road. Mine can go more places!
Old 01-08-2013, 09:15 AM
Itsme's Avatar
Itsme Itsme is offline
Member: #16990
2000 4x4 Xterra
It is more likely that there spark plug areas are filled with water and that is shorting out the plugs.
Plugs should last 100K miles. Ignition wires don't!
The other thing you need to do is remove the distributor cap and wipe off the inside of it, as spark may be tracking on the inside of the cap. (due to moisture and metalic film on inside of cap)
Itsme
2000 X SE
Old 01-08-2013, 03:13 PM
Member: #33663
2003 XE V6 Xterra
Thanks man! I'll get to it
I'm Hunter!
03 XE 4X2
(X) K/N drop in
( ) bull bar
