Stripped out skid plate bolts - Nissan Xterra Forum
post #1 of 6 Old 01-06-2013, 08:38 PM Thread Starter
miskywhisky
Quoted: 30 Post(s)
Ugh, down to 3 now, 1 upper and 2 lower. What did you guys do to replace them? Retap, left it off? Something tricky? Want a sturdy replacement since i plan to hit some snow this weekend.
miskywhisky is offline
post #2 of 6 Old 01-06-2013, 10:13 PM
ayjay
Quoted: 3 Post(s)
No reason you can't: Drill out and re-tap for one size larger bolt, or fill the hole with a weld and tap that (though that will be some HARD ass steel). I've got a small wire feed welder, grinder, sawsall, and such and it makes small repairs like this fairly easy.
2000 XE V6 4X4 5speed, AC shackles and UCAs, Bilstein 4600, K&N drop-in, intake mod, AC Idler brace, Yakima kayak rack, Shrockworks Skids, custom sliders, BFG AT/KO 32x11.5x15, custom rear bumper/swingout tire carrier, custom front tube bumper, Lokka'd front Diff, Gibson Catback, Thorley Headers, Flowmaster Cats.
5 speed
4 WD
3 Pedals
2 Diffs
1 Tcase ... The way it was meant to be.
ayjay is offline
post #3 of 6 Old 01-07-2013, 10:06 AM
intender
intender's Avatar
Quoted: 1 Post(s)
2000 SE Xterra
Garage
Mine are stripped out too. I plan on drilling mine out and welding a nut on the back side. I tried drilling them out and rethreading the holes, but that didnt work out too well. not sure what is on the back side that was threaded, but after I drilled it out to a slightly larger hole there wasnt enough material left to catch a thread on any of the front ones. the back ones I was able to rethread without issue.
<<<-click for build
intender is offline
2000 SE Xterra
post #4 of 6 Old 01-07-2013, 12:04 PM
Mirage
Quoted: 1 Post(s)
2003 Xterra
I stuck helicoils in mine awhile back, haven't had an issue with one since.
Mirage is offline
2003 Xterra
post #5 of 6 Old 01-07-2013, 04:54 PM
TJTJ
TJTJ's Avatar
Quoted: 192 Post(s)
Talking
My issue is more typically about the bolt HEADS being shaved off than the threads stripping...and, yeah, helicoils can fix that.
You can PREVENT stripping by using a torque wrench though.
-TJ
TJTJ is offline
post #6 of 6 Old 01-07-2013, 08:12 PM
intender
intender's Avatar
Quoted: 1 Post(s)
2000 SE Xterra
Garage
are helicoils something you use after they have been stripped out. I have never heard of them before.
whoever owned my truck before me stripped all of them out. I had 2 bolts that looked like stock ones that were cross threaded holding the front on, and 1 in the back that someone had already drilled the hole out and put a 1/2 inch lag screw in it. I am one of the worlds worst at rigging crap up, but thats a sad way to do it.
<<<-click for build
intender is offline
2000 SE Xterra
