X won't blow hot air unless rev'ed up. - Nissan Xterra Forum: Xterra Forums
Old 01-02-2013, 08:57 PM
redbeard redbeard is offline
Member: #37334
2008 Xterra
redbeard is on a distinguished road
2008 Xterra Off-road, Northern Alberta. It could run for hours and won't blow hot air. Even did it inside. Engine comes up to temp fine. Just replaced the thermostat anyway to see if that was the cause. As soon as the RPM is up, in motion or parked, it blows heat. Stop at a red light 5 seconds later, Cold air!
Any thoughts or experience on this would be appreciated.
Matt
Old 01-02-2013, 09:16 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
2nd Gens seem to suffer from an issue occasionally where air in the cooling system will cause heater issues. Take a look at these.
http://www.thenewx.org/forum/showthread.php?t=35941
http://www.thenewx.org/forum/showthread.php?t=37107
http://www.thenewx.org/forum/showthread.php?t=24370
Tags
cold weather, heater, heater core
