2000 Nissan Xterra Stalling and Jerking - Nissan Xterra Forum: Xterra Forums
Old 01-02-2013, 02:31 PM
estarguars estarguars is offline
Member: #38286
200 Xterra
estarguars is on a distinguished road
Ill try to make this short and sweet.
X began jerking on the highway and eventually would stall while running. My friend ran the computer and mentioned the ignition coil was failing. Ended up buying the whole distributor, wires and plugs.
After installing the X would run okay but wouldn't hold an idle. It basically stalls each time i let the gas go. Friend suggested the M.A.F sensor, bought installed and still the same.
$600 deep and the X keeps stalling. Timing belt was changed around 105k, currently has round 115k.
I am extremely frustrated, any suggestions?
Old 01-02-2013, 05:25 PM
RacerXXL RacerXXL is offline
Member: #6445
2000 XE V6 Xterra
Did you re-set the base timing after installing the new distributor?
Old 01-02-2013, 06:53 PM
Member: #38286
200 Xterra
Ill ask my friend (who installed). I am not a mechanic and I appreciate the response. I will update soon. Any other thoughts and tips are welcomed.
Old 01-07-2013, 03:22 PM
Member: #38286
200 Xterra
Distributor was off by 2 teeth, car ran like new for 2 days after adjustment.
Car is now back in the shop because initial symptoms came back before stalling. Now its jerking, misfiring (I think) and occasionally stalling.
Old 01-08-2013, 08:53 AM
kms1990's Avatar
kms1990 kms1990 is offline
Member: #34507
do you know if he set the rotor back to the same postion the old one(thing under cap in old distributor) came off at? that could cause issues as well and which plugs did you get? what brand and double platinum platinum or copper or iridiums? our tuck will run best on ngk double plats or irdiums
MY BRIGHT AZZ LIGHTS!
MY STEREO BEATS EM ALL!
My Laundry List
LIFT()
MUD TIRES()
DROP IN K&N FILTER(X)
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
HID AND PIAA FOGS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
Old 01-08-2013, 09:10 AM
Itsme's Avatar
Itsme Itsme is offline
Member: #16990
2000 4x4 Xterra
As for plugs, the NGK iridiums work best.
Have you checked the large intake rubber for cracks, or leaks where hoses and their components come in. If you are getting air leaks after the maf, the idle will suffer and cause stalling at idle.
The older the rubber gets, the more prone it is to crack and leak air. Even a loose connections will cause this problem.
Itsme
2000 X SE
Old 01-18-2013, 04:43 PM
Member: #38286
200 Xterra
The plugs I am using are NGK Laser Platinums
Update: I've been driving the X for about a week with little to no problems (a little jerking). The weather in Colorado has been around 5-15 degrees.
Today the temperature reached 57 degrees and its been jerking/stalling but this time it wont start back up.
Ill have the X towed to the shop and have them check for leaks, cracks and the rotor. What can the heat possibly cause for the X to act up? Ideas?
  #8
Old 01-19-2013, 03:56 PM
Itsme's Avatar
Member: #16990
2000 4x4 Xterra
The throttle body may be mucked up and need cleaning, to restore good idle characteristics. There also may be an air leak before the TB. Check for cracks and loose hoses going to the intake tube.
Itsme
2000 X SE
  #9
Old 01-19-2013, 11:33 PM
NM2000Xterra's Avatar
NM2000Xterra NM2000Xterra is offline
Member: #17855
NM2000Xterra is on a distinguished road
Check your Maf sensor also...probably could use a cleaning
NM2000Xterra
My favorite mod is my fly rod rack made from duck tape and a hockey stick...
____________________
"That thing looks ridiculous"
"I know, isn't it awesome?!?!"
The Tale of Terra - 2000 XE
More Terra Pics and Such...
  #10
Old 01-20-2013, 09:21 PM
kms1990's Avatar
Member: #34507
i agree clean you maf sensor
My Laundry List
LIFT()
MUD TIRES()
UPGRADE STEREO(X)
RESTORE BUMPERS(X)
FIX UP HEADLINER()
WINCH()
MUFFLER UPGRADE()
